SOURCE: Porter Cable belt sander
try to rig the nozzle of a shop vac to the part where the bag would normally connect and run the sander simultaneously with vac for a few minutes and see if that helps
SOURCE: The belt slips off my Belt Sander
All sander will have two adjustments. The first is to release the sanding belt by retracting the position of one of the rollers. The second adjustment moves one of the rollers belt tension from side to side. The roller angular position is changed, sometime by a single knob or screw, and sometimes by two separate adjusting screws.
SOURCE: After replacing the brushes in my old Rockwell
Did you dress the brushes to the contour of the commutator?
You wrap the commutator with fine sandpaper and rotate under the brushes till the curve conforms.
If this does not reduce the arcing, then you may have an armature with a bad winding.
Testimonial: "Sounds logical. I'll try it."
SOURCE: looking for a manuel for a makita belt sander model #9401
There is a black metal ******** one side that is actually a lever and with the tip of a screw driver or the like, pops out and releases the front roller.
