Have igloo wine cooler FRW1201 and replacing part TEC1-12706 Heatsink thermoelectric cooler peltier plate module. Wine cooler is 12v & 70w input power. Part is available in both 60w and 92w, how do i find out which one to order?
SOURCE: Oster wine cooler (peltier diode)
I called the contact in one post below, and he was VERY helpful. Took all my info, submitted to the division handling this and they overnighted me a check for the entire amount plus tax for the wine cooler to me! Call Jason!
Jason's contact info is:
Jarden Consumer Solutions
2381 Executive Center Drive
Boca Raton, FL 33431
(561) 912-4100
SOURCE: Wine Enthusiast 16-bottle thermoelectric wine refrigerator DEAD
usually bad power supply, if the cooling fan isn't running either. These are horribly inefficient coolers that use a lot of power to accomplish little cooling. The power supplies are quite notorious to burn up.
If your supply is 12vdc output, you might be able to replace it with a supply from radio shack. dont use a battery charger though.
SOURCE: where can I order a
Hi, try Sears parts direct online first. They carry a wide variety of parts for several makes and models of wine coolers.
SOURCE: My haier HVW18 unit sounds
Can you explain what you have done and what you have find ? Did you spot the heat sink ?he aluminium part with louvrs?
It sounds like your temperature control is not functioning correctly. Most temp controls still have a small mercury switch somewhere in the cooling circuitry. I would hazard a guess that if you can turn the dial to different temp settings and it always goes to freezing at 0C or 32F that your temp switch is either bad or the mercury switch (which tips forward or back depending on the setting to make contact and start the compressor) is stuck somehow so that it always sets to the lowest possible setting for your Wine Cooler. Without actually looking inside and testing circuits, that's my best estimation of your issue. Hope that provides you with a starting point to talk to someone who can help you repair it.
