Hi Patricia Smith, indicates the LG TV model you are commenting on, in order to find the best possible solution
As Tom tells you, it is very possible, a blown fuse or malfunction of the power supply
I wait your answer
Regards Franco Dosil
Hola Patricia Smith, indica modelo del TV LG que estas comentando, para poder encontrar la mejor soluci?n posible
Como te indica Tom, es muy posible, un fusible quemado o mal funcionamiento de la fuente de alimentacion
Espero tu respuesta
Saludos Franco Dosil
SOURCE: 37'' LG lcd tv, no power
I just want to clear things here.
The stand by light will remain on whenever the tv set is turned on by a button on the side of the tv.
Then use your remote to turn on the tv, but wait as it can take 10secs before you get a picture.
SOURCE: lg tv modle DU-37LZ30 on off indicator light is
Most likely a power supply problem. I recommend taking this to a certified technician and having them look at it.
SOURCE: LG 42 inch Plasma TV stopped coming on. Now
With this symptom, it is impossible to tell what the exact "Cause" of this symptom is. The LED's do not tell us what is wrong, sometimes it may indicate the "Area" in your case it is the X board. BUT thats NOT where the "Fault is" thats just the part that is affected. These days unlike the "Old" analogue days it just isn't realistically possible to fix anything but the most basic of problems with todays sophisticated units. This is quite apart from the Safety aspect, any unit that can cause a firs or have an explosion, or both, is NOT to be treated lightly, and and the repairer, of the unit is legally responsible, another thing to think about. Also, one must have tools, a Multimeter, a soldering iron, a deslodering iron, an oscilloscope, a signal tracer, tools, and most important of all, a Service Manual, without which, there is no way to even begin to understand and fix it, and more importantly Program it, AFTER it has been fixed. As these days a TV, is a PC, a Tuner, and an HDTV Monitor, and more, all in one. in the "old" days TV"s were more, rudimentary, and built to last for 20 years, and a "Parts" supply was set aside. They usually used to fail for only a few reasons, and they while still difficult, were less difficult to repair. Electrical knowledge was transferable, and they could be and would respond to, This-is-the-symptom-This-us-the-Fix, But that no longer applies, as now, it can be a Fault on I squared Bus, or "Sensor" failure, or it simple may have "Crashed" just like a PC, It could be a Diode go bad, and that will stop the whole thing. You see, in the day, the sets were Very "Fault Tolerant" because they were Analouge, and a faulty, component, or more sometimes, the set would always diplay something usually, and when they didn't it was one of anly a few things, sure there are always the horrid ones, and there are pleanty of those, but all in all it was quite easy. But with Digital Electronics, it either goes, or it doesnt, there are usualy few half measures. I mean thats the definition of logic either going or not. So it can take very little to completely paralyse a set, and generally give the only sysmptom, it can, by not working, usually No picture, or the like. So you, see the list is endless almost for any given SYMPTOM, as that is what is being seen, not the cause, as I keep going on about. Also any fault, usually involves the Power Supply, it is either the cause, the cause of the damage, or it is damaged. or ALL of them. Then after you have done the electronic repairs, you then must program the set to work, and align, and set up in general, any one of those settings missed or done wrong, back to square one. So, it is nearly always my professional opinion that one should always get a "Quote" form the manufacturers recommended service center, I cannot stress how important that last point is. It is even worth the cost of shipping. you see an authorised service agent, will have trained staff, trained on their brand, also they have first hand access to parts, original parts. This will actually save you money and ensure you can actually get it back fixed. Of course asking for a "Quote" also gives on the option of repair or replace. Often my clients,do not go through with repair, unless it is moderate, but in some of the more costly jobs they see it, as do i, that a replacement, with a warranty, is a better option. As an aside here, one could then tear the TV down, and sell the Known Good bits. You'd be surprised who needs parts, i myself often must by from third party sources to effect a repair. So money could be recouped, somewhat,and help out someone else.
SOURCE: lg lcd tv and the liquid crystal display light is on
U have cables,satalites or telicom compannies pay services?Unplug the tv and any of those services box about an hour,replug both back let the box upgrade it software.Turn on the tv.The tv push the button on the remote said Menu.PICTURE go down to reset,the tv now reset it back to factory setting.The air broscasting signal,now should on ur tv.
SOURCE: TV not working
Are you using the correct input for tv reception?
If you are getting the LG screensaver then that suggests that the video circuits are good. Since the menu is working, try connecting something to one of your video inputs and see if that works. It should.
If so, then the difficulty lies with the fact that there may be something wrong with the tuner section of your television.
Testimonial: "So it looks like all 3 HDMI inputs are gone as I was able to get it working through either the RCA phono's or the composite video inputs. Probably needs a new main board but I can live with the work around for the time being. Thanks"
