Hi Delroy Atkins, what you call, waveguide cover, is this the Mica plate?
Indicate the microwave model you are commenting on, in order to find the best possible solution
I wait your answer
Greetings Franco Dosil
Hola Delroy Atkins, lo que tu llamas, cubierta de la guia de ondas, esta es la placa de Mica?
Indica modelo del microondas que estas comentando, para poder encontrar la mejor soluci?n posible
Espero tu respuesta
Saludos Franco Dosil
Usually wave guide are not replaceable. It is time to go buy a new microwave oven.
SOURCE: Dacor Microwave
Quite often this is due to grease or food particles stuck to the inside of the oven or stuck on or behind the waveguide cover.
The waveguide cover is usually about the size of a playing card and often held in place by a plastic rivet.
It can be fragile, and the metal edges of the oven behind it can be sharp, so be careful!
The cover and the metal behind it should be cleaned with a mild, non-ammonia cleaner.
If the cavity metal of the oven is chipped or charred, it will have to be sanded smooth and clean.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
If your waveguide cover is burned, it will need to be replaced.
The part would be much cheaper if you get the Sharp version (these ovens are made by Sharp) instead of the Dacor branded part.
The model DMT2420 is essentially the same as model R440D / R540D.
The Sharp part number is PCOVPB085MRP0 (zero on the end) and you can order Sharp parts from Tritronics at http://www.wehaveparts.com
We're happy to help and we appreciate your thoughtful rating of our answer.
SOURCE: microwave ovens
The Magnetron has failed, causing the waveguide to become damaged. If the waveguide is damaged/burned the microwave can not be repaired and should be replaced.
SOURCE: Sparks from the interior of the microwave
Quiteoften this is due to grease or food particles stuck somewhere in thecavity of the oven or stuck on or behind the waveguide cover.
It can be fragile, andthe metal edges of the oven behind it can be sharp, so be careful!
The cover and the metalbehind it should be cleaned with a mild, non-ammonia cleaner.
If the cavity metal ofthe oven is chipped or charred, it will have to be sanded smooth andclean and dried thoroughly.
Then you can apply somehigh-temperature appliance paint, available from places like Wal-Mart,Lowe's or Builder's Square.
If your waveguide coveris burned, it will need to be replaced. It provides importantprotection for the magnetron.
You can findhelpful exploded view diagrams and order parts by entering your fullmodel number here.
We'rehappy to help you with free advice and we'd appreciate yourthoughtful rating of our answer.
SOURCE: GE Microwave is arcing inside
In some models it is the plastic ceiling.
If the cavity metal of the oven is chipped or charred, it will have to be sanded smooth and clean and dried thoroughly.
If you need more specific help, please reply back with your brand and full model number.
William E. Miller, AS-EET
[email protected]
http://www.microwavedisplay.com
