Some places to check
Maytag MHW6000XG2 front load washer diagram and/or - fusewasher fuse location asko-undefined-undefined-5_0.jpg location asko-undefined-undefined-5_0.jpg" alt="fusewasher Maytag MHW6000XG2 front load washer diagram and/or - gehydrowavefusecheck-undefined-undefined-9.jpg" class="h_mi" />
SOURCE: Torn bellow on Maytag front load washer
there is a spring style clamp holding it to the front panel simply peel back slightly and "pop" it off, then holding it to the inner tub is a screw style clamp, depending on yr of production, either a 5/32 scrwe or a phillips, holding it in the 2 oclock position, release clamp andreinstall boot, it might take some time to get to fit backaround hte tub but itll bo, you gotta walk it on in spots ( like changing a tireon the bikes as a kid) itlll strectch over the rim and fit, just have to work it
SOURCE: maytag Neptune front loader rubber boot replacement
can be done just need PATIENCE!.. youll need ot remove the door assembly, and the 2 screws oppisirethe heing willalow for the front "u" shaped panel to be reomved.. next remove the 4 screws from with in the dispenser area, and then there are perhaps (6) 5/16 screws holding the nextfront bulkead and maintop assy down.. after removing theese screrws youll be able to lift eh main top back wards( prop it with something, a few more screws will release te hlatch assembly.. from here you can probably install the new bellow, remove the spring and wire, and the work the new bellow around the tub lip. a third hand will come in handy, after working it around , youll needto reconnect the tension spring..HARDEST PART OF JOB>>> REQUIRES PATIENCE!!!!!. sometimes this goes on for me with out issue in 5 min, other times 25 min and im PISSED AT IT!!!!!!!,, wrap the wirer around bottom of lip and your going to hold one end of spring, needlenose vice grips work perfectly. then with another set of needle nose. stretchthe spring togethr to lock the wire around.. whern you finally get this reassemble the latch and drop the top back down replace all teh screws, and finally you need to retuck the bellow into the front bulkhead( tabbs line it up nicley.. good luck!!!
SOURCE: replacing door gasket on maytag neptune MAH5500BWW washer
I need to know what are the steps to replacing the door gasket, I would like to know what to take apart, and what not to take apart. Like a step by step lay out.
SOURCE: I need to replace the molding door boot seal on my
you need to first unplug the unit. next you need to remove 4 screws that hold the dispenser lid on. next open the door remove 4 screws. remove the door and the out side panel. next located to the top left and right you will see a bracket with a 5/16 bolt remove them and take the bracket off. next lift the lid. you will have access to the door seal. you will see a spring at the top that is the band that holds the seal to the tub. the front of the seal just peels off. when putting the band and spring back on may be a little tricky. get one side up to the top gett a piece of duct tape and secure it. so that you can properly get the rest of the band on without fighting with it. get some vise grips and pull the spring over and attach to the part that is tapped. let me know if this helps or if you need more instructions.
