SOURCE: My new Lionel CW-80 trans former stopped working
I have had the same problem with my polar express, which i just bought recently. Having to send it to the USA from the UK would be very expensive so i decided to open it up myself. The tamper proof screws were a bit of a problem getting into it. I ground down an old screw driver into the triangle shape to undo them. I then replaced them with self taping srews the same size.
The Problem I found was simple, there is an internal (250V, 8Amp) fuse soldered onto the red wire on the secondary winding of the transformer. The red wire going from the transformer to the PCB, the fuse has black heatshrink over it.
There is no room inside the housing of the controller to fit a fuse holder. I fitted a box on the side of it with a panel mount fuse holder. drilled a hole through the housing, fitted longer red wires, so they could go through to the terminations on the back of the fuse holder.
At least now I can change it simply if it blows again.
hope this is of help to you.
SOURCE: Peg Perego Thomas Train Track Rider
I cannot promise that this is the problem, but this is where mine was broken, and you may be able to fix yours this way.
I was able to remove the plastic around the tender and access the motor. Using alligator clips, I was able to connect the battery directly to the motor, bypassing the circuit board. The motor functioned, therefore the only component that seemed to be defective was the circuit board, located behind the speaker in the engine unit.
As far as I know, the only place to buy a replacement circuit board is from www.tigerimports.com. Search for part number MEVA0024. Cost is around $15 + shipping (around $6 or so).
I should be receiving this part by the end of the week and will report if it fixed the problem.
Thanks for using Fixya. If I didn't help your situation, please DO NOT label this advise as "inappropriate".
Hi
Have you tried keep pressing the right hand button down. When you press the button down and hold the press, then the sounds are finished, the trains starts driving. When you release the button the train stops at once.
SOURCE: Have lost instruction manual for THOMAS ULTIMATE TRAIN SET byTOMY
http://www.tomy.co.uk/webcare/product-instructions/track-master-tmrr-instructions/
SOURCE: I am trying to hook up a Lionel 1033 transformer
I have the original Instructions for Operating the 1033(written in 1953) - the second paragraph of the "How To Connect Transformer" reads as follows: The "Multi -Control" transformers listed in this leaflet have four binding posts located on the top of the transformers. Of these, "A-U" and "B-U" combinations furnish variable voltage for the track. The control arm of the transformer simultaneously regulate the voltage output of both the "A-U" and the "B-U" combinations. The transformer nameplate indicates the voltage ranges of these two combinations.The "A-U" combination supplies any voltage from 5 to 16 volts. The B-U combination has voltage from 0 to 11 volts. In selecting the proper range of voltage for your particular outfit, try the lower "B-U" combination first. If the maximum train speed is not satisfactory, then try the "A-U" posts.
To paraphrase the "How to Connect Accessories" section: accessories work best with fixed voltage - these voltages are obtained from the following pairs of output binding posts: "A-B" 5 volts; "B-C" 11 volts and "A-C" 16 volts.
Hope this helps, Mark
