SOURCE: drill chuck swap
1. Turn the screw clockwise to take it out.
2. Then you needs 3/8 allen key & insert the short side of the allen key & tighten the chuck.
3. hold the drill at the edge of the table & wack the allen key
counter clockwise & do it again as needed.
4. dewalt keyless chuck will fit but you might add a washer to insure the chuck is not rubbing the clutch collar.
5. putting it back together the other way.
SOURCE: The tires are flat
You need to purchase an adapter which pushes onto the valve (so it doesn't depress the valve stem) and the other end is a standard screw fix to a bicycle pump.
Any good bicycle store stocks them.
The valve you are desrcibing is pretty standard on racing type bicycles.
Good luck and let me know how you get on.
SOURCE: I need to replace the bent shaft that the chuck screws onto
I would go direct to Dremel.com or call them at 1-800-437-3635 and get the schematic and parts you need, I just checked and they have a parts diagram online that you can view. go to the section about manuals/literature and type in your model number. Good luck
SOURCE: Chuck broke on Skil hammer drill
As long as the new chuck threads onto the old spindle then any chuck will work fine.
SOURCE: craftsman 3 gal ari compressor low presure
put a blower on the hose and see if air comes out
very possible there is a blockage in the hose or if you are using quick connects they may have failed
