Washing Machines Logo
Jodi Charest Posted on Sep 30, 2019
My Whirlpool cabrio top loader washer with a touch screen won’t turn on no lights or sounds when plugged in. Breaker was reset (even though the outlet had power to both sockets)
Adrienne Hernandez
Level 1:
New Friend:
Problem Solver:
  • Contributor 12 Answers
  • Posted on Sep 30, 2019
Adrienne Hernandez
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
12
Questions
Helped
3220
Points
30
Check repairclinic.com
5 Related Answers
Anonymous
  • 1122 Answers
  • Posted on Oct 18, 2008
SOURCE: whirlpool duet ht wouldn't start
remove the lower front panel,3 screws,side up and off,there is a tech sheet inside on the panel that should help you ,let me know what you find-mike
Anonymous
  • 180 Answers
  • Posted on Nov 27, 2009
SOURCE: Whirlpool Cabrio top loading washer F1 Error
F1 means the control board is shot. Call whirlpool and they should take care of the parts and labor even though your machine is out of warranty.
Sal De
  • 2699 Answers
  • Posted on Dec 13, 2009
SOURCE: F1 code whirlpool
whirlpool F1 code - Appliance Repair Forum THERE IS A RECALL ON YOUR WASHER,CALL THE FACTORY AND GET IT FIXED FOR FREE
Anonymous
  • 572 Answers
  • Posted on Feb 06, 2010
SOURCE: The lid will not lock on my Whirlpool Cabrio
id change the door switch
Anonymous
  • 1998 Answers
  • Posted on Jul 14, 2010
SOURCE: mywhirlpool cabrio WED6200Sw0 dryer doesn't turn
whirlpool cabrio infamous for blowing out control boards check with a multimeter to see if you have power going into the machine and trace the lead power wire to the control board most likely it is your main control board hope this helps
Whirlpool washer Wtw4816w2 will not reset. Tried numerous times as explained in add details.
If you haven't power reset then;
Disconnect the Cabrio from power, unplug or flip breaker off.
Wait 5 minutes before restoring power.
If it still won't respond, then likely a control board/power and/or interconnect issue.
My washer ( Whirlpool Cabrio M: WTW6500WW) will not start, cancel, rinse nothing! I can't even properly diagnose it because every button I press gives me an error chirp?
it sounds like you have a bad touch pad,try unplugging the machine for a few minutes to see if it resets the board,i would call the factory on this,they've been having problems with this and they might give you the part for free but you'll have to pay for the labor.
http://www.repairclinic.com/PartDetail/Touchpad-and-Control-Panel/W10070060/1202650
this could be the problem
2answers
My whirlpool cabrio washer #wtw555oxwo won't work. The lid lock light keeps flashing and the washer won't start
Possible that the switch is defective, there is fault in the line to the control unit from the switch of the control unit is faulty.
check these one by one.
I lost Power from a Thunder Storm and now my Whirlpool Cabrio top loader won't open
Thats sounds as if the lock asm is stuck. As soon as the power went off the lock would have de-energized and should have opened.
Too check the lacth for sticking open the top by placing a putty knife in the seam between the top/front cabinet panel at the corners and push in to release the clips that hold the top to cabinet then raise top and see if something appears to be stuck on latch asm.
Gene
What would you recommend for a good super capacity top loader washer? My 15 year old Whirlpool just died. Don't really trust electronic controls, reviews of he top loaders are so mixed, I am unsure. Also...
To be honest I really don't trust electronic controls due to the fact that the majority of the repairs i do on front loader machines has to do with the electronic controls. In my opinion top loaders are more reliable. they get the job done. If you were to get a top loader i do recommend whirlpool, even though i agree that the quality is down. I also like the whirlpool cabrio, its a top loader but has electronic controls. it uses less water and soap just like a front loader. Whatever you do decide to purchase, I highly recommend that you purchase the extended warranty. This way if there is ever a problem, you know that you are covered.
1helpful
I have a cabrio top loader washer and I'm getting a LF error message
Hi
Thanks for using FixYa. Error LF means long fill, which flashes when the water level won’t change for a period of time after the valves are turned on or the water has disengaged the basket but control does not detect a water level change. TO resolve this issue check if the water supply is turned on and the hose screens are not plugged or kinked. If the water is not entering the machine then check the water valve, also check the pressure hose connection to the machine/motor control. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
2helpful
Whirlpool Cabrio Washer WTW6600S turns on but does not do nothing
Try unplugging it for a few minutes then plug it back in. If it does not reset then the controller requires replacement. Hope this helps... Bill
Washer wont do anything after it fills
try your outlet,,plug something else there to see if you have current if so make sure breaker is 15 amps or better with washer on line alone..if good bad door switch..
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
