Tools & Hardware - Others Logo
M
Michael E Brittin Posted on Sep 30, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do you assemble a dremel flex shaft 225-01
Mike
Level 3:
  • Master 4,383 Answers
  • Posted on Oct 02, 2019
Mike
Master
Level 3:
Answers
4383
Questions
Helped
1261528
Points
17064
You screw off the collar on the tool, remove the chuck and inner part. The chuck is replaced with a special chuck (no inner piece). The special chuck has a square opening in it's nose that accepts the square end of the flex shaft inner cable. Is is actually a speedometer drive cable, from yesteryear.
Then you pull the inner cable out slightly, if it will, and put the inner cable into the square opening of the special chuck on your dremel motor. once engauged, you carefully screw the outer shaft housing on to the end of your dremel motor.
What you want to avoid is damaging this area during flex shaft assembly. I have had success with turning the output side of the flex shaft, while tightening the outer flex shaft onto the dremel motor. Stop tightening if it starts binding...
Rotation seems to help with alignment of all parts.
Cheers,
Doc
5 Related Answers
Anonymous
  • 2176 Answers
  • Posted on Dec 24, 2008
SOURCE: Dremel Flex shaft attachment model 225
Dremel has an exchange program for the 225 Flex Shaft. Send your flex shaft and 17.90 and they will exchange it for you. Send it to DREMEL 4631 E. Sunny Dunes Rd. Palm Springs, CA 92264 Their phone number is 1-800-275-2052. Hope this helps. Dave
Anonymous
  • 2176 Answers
SOURCE: using the flex shaft attachement.
I dont think it should get that hot. Dremel has a program for the 225 Flex Shaft and for 17.90 they will exchange it for you. Send it to DREMEL 4631 E. Sunny Dunes Rd. Palm Springs, CA 92264. Their phone number is 1-800-275-2052. Hope this helps. Dave
Anonymous
  • 2176 Answers
  • Posted on Feb 17, 2009
SOURCE: broken flex shaft on Dremel model 232 broke
You can go to Dremel.com and find assistance or call their toll free number at 1-800-437-3635 and speak with their tech assistance. Let me know if you still need more help. Also I tried using the model number provided and it came up empty that is why I am directing you to this site yourself.
Robert Koch
  • 165 Answers
  • Posted on Mar 02, 2010
SOURCE: flex shaft attachment
Takes an adapter to screw onto the nose of the Dremel. The shaft itself is gripped by the correct size collet tightened as you would any bit.
Anonymous
  • Posted on Feb 12, 2011
SOURCE: Dremel shaft lock spinning
Trying to fix a similar issue. The pin that gets pushed in by the button (and returned by the spring) seems to be fine. The hole in the rotating shaft that the pin fits into, however, is in the wrong place, so the pin never goes into the hole! All I need to do is somehow pull the whole front part of the shaft out about 1/16th of an inch, and it'd be fine. I just can't seem to budge it though. Any tricks, anyone?
Turn the dremel on the bit doesn't spin
My motor was turning but the flex shaft wouldn't. I took the flex shaft loose and spun it inside. Works fine now.
1helpful
Have Dremel MOD 395 motor runs and speed control works bot shaft won't turn--worth fixing ??? and how
Hi Larry, The tool that you require parts for was discontinued many years ago. Limited parts are available from Dremel. Inside the tool is a flex coupling and spline driver. The flex coupling is # 2615294309 and the price is about $ 1.25. This is the hollow plastic sleeve about 1" long with grooves on the inside, that goes between the motor shaft and the output shaft. The spline driver is # 2615294308 for about $ 1.00. Spline driver sits on the direct end of the motor shaft. The flex coupling sits over the spline driver. Spline driver is about 1/4", hard plastic with grooves on the outside. Total shipping for orders under $ 5.00 is $ 2.50. Orders over $5.00 is $ 4.00. There could be a tax charge depending on which state you live in. Here is how to order: Call Dremel Customer Service at 1-800-437-3635 , Monday-Friday from 7 am to 6 pm central time. VISA, MasterCard or Discover to place a Visa, MasterCard or Discover order. To order by mail: Dremel 4915 21st Street Racine, WI 53406 USA 1-800-437-3635 ext. 3636
Replacing the spring in the Flex shaft attachment for Dremel Model 225
Use a piece of wire with a right angle hook on the end Push the wire down until it is inside the spring lever sideways and pull out.
Flex shaft attachment won't work
find the little square attachment and place on the end of the dremel tool. I didid the same thing. Worked fine after I put the other part on.
One end of the 225 t2 is a large receptacle with threads inside and a shaft below the threads.I have no adapter to connect it to the Dremel. The FlexiShaft came with the variable-speed Dremel but no...
To use the flex shaft, you need to remove the bit collet. Included in the kit is a nut looking item--mine is silver. It has a square end and screws on to the end of the dremel. It is simlar to the collet, but is slightly smaller. Then you place the square end of the flex shaft into the nut and screw the shaft on to the dremel.
Hope that helps
2helpful
32helpful
3answers
My Dremel tool motor still works but shaft won't turn?
Here's the email from I got from Dremel (in my case the flex coupling broke):
The flex coupling is # 2615294309 and the price is $ 1.25.
The spline driver is # 2615294308 at $ 1.00.
5.00 is $ 4.00.
I have provided ordering instructions below.
To order by phone: 1-800-437-3635, Monday-Friday from 7 am to 6 pm
central time. VISA, MasterCard or Discover is accepted.
To order by mail:
Dremel
4915 21st Street
Racine WI 53406
3helpful
Broken flex shaft on Dremel model 232 broke
Using the flex shaft attachement.
Top Dremel Tools & Hardware - Others Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Dremel Tool and Hardware - Other Expert? Answer questions, earn points and help others
