SOURCE: Trying to clear the codes from my Garage Door
In most cases, when a garage
door opens or closes by itself, or when you find your door open, upon
returning home, the problem is due to a short somewhere. This short
is most likely to be in one of two places: either in one of your
transmitters or in the wall button or its wiring.
When there is a short in your garage door transmitter, you will
often find the garage door is up upon returning home, even though you
know you closed the door when you left the house. A short in your
transmitter causes a continues signal to be sent. As you are pulling
out of the driveway the garage door closes fully and appears to stop,
but as the carriage and arm run past the down limit and hits the
header bracket it reverses, and the door begins to open, just as you
start driving off down the road. You come home to find the garage
door is up, as if someone else had opened your door. The best thing
to do to troubleshoot the garage door problem is remove the batteries
from your transmitters and try operating the door from the wall
button. If the problem is intermittent, you may want to do this for a
day or two to eliminate the transmitters as the culprit.
If the problem persists, try removing the wall button wire at the
motor head to ensure it is not a short in the wire to the button,
then try operating the garage door with the transmitters only. If it
stops the problem, replace the wires and test the wall button. It is
a process of elimination.
SOURCE: programming my keyless entry
Yes, you purchased the wrong wireless. You must get a Genie keyless and there are two types of Genie keyless (GWKP & GWK-BL) depending on which Genie operator you have. You might think about a wired keyless entry (Domino GD-1). Then if you change your operator you don't have to change your keyless.
SOURCE: Trying to program a keyless pad for a chamberlain door opener
pressing all buttons firmly....
1) on the keypad, enter your 4 digit code, press enter once
2) on the operator head, press the learn code button once
3) (within 30 seconds) on keypad- enter 4 digit code again, press (slowly) enter, enter, enter
the opener should be programmed
SOURCE: changed code on the wireless chamberlain security key pad
Does it work from wall button? Hit learn button for 10 seconds. Hit again for 1 second and code keypad.Opener lights should blink 2x. Hit learn again for a second and hit button on a remote (Any button you chose). Again, lights should blink. Now should work. Repeat for any other remotes.
SOURCE: How do I program my Genie garage door opener to my 2005 Kia
GOTO HOMELINK.COM
THEY MAKE THE SYSTEM AND HAVE INSTRUCTIONS YOU CAN DOWNLOAD.
PLEASE NOTE: NOT ALL BRANDS/MODELS OF OPENER WILL WORK WITH THIS SYSTEM.
HOPE THIS HELPS
Locate
the smart/learn button on the rear of the motor unit near where all
those white wires go. Press and immediately release this and then
walk over to the keypad and key in any 4 digit code you like and
press enter.
If this doesn't work then the keypad is bad or it is not the proper model for your opener.
