Toys Logo
Anonymous Posted on Sep 29, 2019
How to adjust the clutch on a massey ferguson 50
Don A
Level 3:
  • The Master 4,495 Answers
  • Posted on Oct 07, 2019
Don A
The Master
Level 3:
Answers
4495
Questions
5
Helped
1336288
Points
25824
5 Related Answers
Anonymous
  • Posted on Apr 07, 2009
SOURCE: massey ferguson 3655
sounds like the seals are gone on the 4wd shaft, it takes oil pressure to keep the 4wd off, but if the seals are worn the all passes through and the 4wd will not dissingage, you will need a experianced michanic
Anonymous
  • 86 Answers
  • Posted on May 12, 2009
SOURCE: Operator's manual for a Massey Ferguson 65 tractor
Go to google search engine and type in your tractor most of the time it will give you lots of web sites to look at.
Anonymous
  • Posted on Nov 21, 2009
SOURCE: What kind of oil goes in a Massey Ferguson Tractor
What model tractor - MF130/135 diesel takes 10/30 not gear oil for transmission/hydraulics
Robert Koch
  • 165 Answers
  • Posted on Feb 27, 2010
SOURCE: Massey Ferguson 35 has no spark, I have replaced
Test the plug wires, coil wire---could be the ends of the wires. Points could be burned and replace the condenser?
Anonymous
  • 13 Answers
  • Posted on May 01, 2010
SOURCE: What sort of oil is used in the gearbox of a
The Massey Ferguson's use the same oil as the N series tractors. 90W for the transmission.
2answers
Have a Massey Ferguson 2615 that's stuck in foward gear and won't come out of gear. Tractor does stop when clutch depressed and hi/low still works. Need Help
Did you ever figure out what the problem was with your 2615 Massey Ferguson tractor and why it was stuck in gear. I have one that is doing the same thing
Jan 30, 2016 • Toys
How do you wire Massey Ferguson 230 diesal ? With 3 wire delco alternator. Along with oil pressure switch , ammeter, neutral safty switch, fuel,water. 12 volts.
    mages for wire diagram Massey Ferguson 230 diesel
    More images for wire diagram Massey Ferguson 230 diesel
    230 MF - wiring diagram - SSB Tractor
    www.ssbtractor.com/wwwboard/view_all.cgi?bd=massey&msg=10416
    Allen Stewart, I need the wiring diagram of the dash area. Does anybody have this? Allen Stewart, wiring diagram is needed for Massey Ferguson 230 diesel.
    [PDF]MASSEY-FERGUSON - MyeDocs.com
Jan 01, 2016 • Toys
3answers
Who has manuals for the Massey Ferguson 230?
contact the manufacturer on line for any available pdf downloads.
try e-bay for manuals.
How do I fix a clutch on Massey Ferguson 165 1979 tractor. I need a manual to do repair on farm
This is easy. If you live on a farm i assume you have some mechanic abilities. the tractor needs to be split in half. I have done these tractors in as little as 4 hrs. The easy way to seperate the tractor is to sleightly jack up the middle of the tractor,put a jack stand under the front of the transmision. Now move the floor jack forward to the rear of the engine. take roughly half of the weight off of the jack stand. this will allow you to roll the front half of the tractor away from the rear once you remove the trans.bolts,hydro.lines and brake rods.
How do i adjust the clutch on massey ferguson 135
check if it has a rod between pedal and throw out leaver should have a thread adjustment.
Aug 12, 2014 • Toys
Top The Toys Experts
Paul Carew
vince
Are you a The Toy Expert? Answer questions, earn points and help others
