SOURCE: plz help me unlock my security code..Nokia 6288
hi, i can give you the master code but you need to read this first ok.
1. the master code wont work if you have entered 5 wrong codes as the phone will be hard locked and can only be unlocked using flash lead and unlocking software.
2 the code only works if the phone asks for security code when first swtched on.
If you have not entered 5 wrong codes then this master code will reset the security code and remove it unless you want to put another security code back on the phone.
enter this code when asked for security code ok 4365426660.
This code will only work with your imei number as every single phone has a unique master code based on the imei number ok so double check the imei number before trying the code.
Any problems just give me a shout back ok.
SOURCE: We have a sharp cash
Hi Wellsey,
The error "E34" means there is on overflow limitation error.
This means that the amount tendered is greater than how the machine is set-up to accept.
Try entering a smaller amount pressing TL/NS then enter the balance given or even break the amount up to three or four entries, the machine will show the outstanding amount to pay each time and deduct each entry from that balance.
Having done that and finalising the transaction you will then need to do the following to prevent this from happening again.
Refer to page 46 of your operators manual and set the parameters of job67 to those that suit the country that you are in.
Regards
Gavin.
SOURCE: My cash register (Sharp XE-A202)
Ok. This means you have accidentally programmed an amount limitation. I can help you with this. You need to tell me which button is making the error appear, then we can sort it out.
Mark
SOURCE: sharp cash register XE A202
finally solved this problem...yeah
first press CL
then ESC then ESC
then 1 (grey button)
then CLK#
after this step your screen will show - 01 -
now your register is ready to go..
good luck.
SOURCE: i have a sharp xe-A202 which is showing message
Sharp Electronic Cash Register XE-A202
Will not print out receipt. Paper will roll out. just not printing
