Computers & Internet Logo
Jessi Dean Posted on Sep 27, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My son has a nexbook 11A he will be using it and the screen goes black & wont come back. He restarts it and it works for a while but keeps blacking out. is there a way to fix this?
Level 3:
  • The Master 19,187 Answers
  • Posted on Sep 27, 2019
The Master
Level 3:
Answers
19187
Questions
0
Helped
4341920
Points
82259
The troubleshooting of any computer involves resetting it back to factory settings. That means all data must be conserved if you want to be able to use the data, pics etc again. After backing it up you can perform a factory reset on it to see if the problem goes away. There are risks involved in this process. You may end up with a brick. The reset procedure is well documented on you tube.
5 Related Answers
Anonymous
  • 293 Answers
  • Posted on Nov 13, 2008
SOURCE: my Dell Monitro goes black about 4 seconds after being turned on
Hi..there,
It's seems you got a busted backlight inverter. Need to replaced a new one or repaired it.
Anonymous
  • 66 Answers
  • Posted on Feb 16, 2009
SOURCE: Acer 5315 goes to black screen with cursor
If it's only 5 months old, then it's still under warranty. Right now, I'd advise taking it back to have it fixed instead of taking it apart to replace hardware and possibly voiding a warranty.
ROD GANDY
  • 1602 Answers
  • Posted on Mar 14, 2009
SOURCE: wont come outof hibernation goes to a black screen even upon rest
RESTART IN SAFE MODE.
OR
REBOOT SYSTEM, BEFORE IT BOOTS PRESS
F6 UNTIL YOU HEAR THE BEEPING NOISE, THAN STOP AND SELECT SAFE MODE
THAN CONTROL PANEL AND SELECT POWER OPTIONS
POWER BUTTON OPTIONS
Starfish Phoenix
  • 73 Answers
  • Posted on Apr 21, 2009
SOURCE: screen comes on for a second then keeps going black, if I turn monitor on and off it will come on but then goes right back off again
Broken powerboard/inverter in the screen presuming its an LCD. Can be costly to fix
Anonymous
  • Posted on May 13, 2009
SOURCE: To fix the pitch black screen
just take the positive cable off your battery and that will reset in to the factory settings and that should fix it
My hp g62-341 nr notebook screen keeps going black on me
It sounds as if you have a broken wire on the motherboard, as it heats up to a certain point, then that wire separates with a gap between the two parts, which causes your PC to simply go black on you, and if it cools enough, it will work again.
You need to get HP to look at this problem, either through contacting their support people, or arranging for them to take it back and work on it.Good luck,
-a,
Too many! Where do I start.... 1. The Wifi connection does not work, although blutooth is on and the blue indicator light is illuminated. 2. When the pc is idle for some time, the screensaver does not...
This can happen when there is two problems.. One the computer might have been affected by virus.. Or the other thing might be the OS corrupted.. Try to get into safe mode and check if the system is working fine.. If it works well there try to do a system restore to a place wr it was working well.. If in safe mode also it doesnt work well then go ahead and reinstall the OS...
3helpful
2answers
My laptop Preasario cq61 has the black screen problem, when it starts it shows the first screen fine ( the one where you can hit ESC to enter the bios) after that it goes black and in the top left corner...
http://h10032.www1.hp.com/ctg/Manual/c01141784.pdf
OK download that service manual, follow the troubleshooting procedures and you will sort your problem out in now time, i have a hunch, that your HDD, is faulty... and may need replacement. Anyway Download and use that manual, it's a generic one.. but will still work for you.
MY LAPTOP WONT GO TO THE START MENU
you need to click ctrl+alt+del hit cancel and it will work :)
2helpful
Wont come outof hibernation goes to a black screen even upon rest
OR
2answers
Acer Extensa 5210 laptop wont boot
Try the following:
1) Remove power cord, battery and hold the power switch down for at least 30 seconds.
2) Remove and reinstall your memory module(s).
If those don't do it, get back to me for more ideas.
Thanks!
Ron
Screen goes black
It may be a failure in the controler section in the player. This will need service. Most likely, the cost will not be feasible for this type of repair. You will have to send it to the authorised service for the player.
Jerry G.
Top The Computers & Internet Experts
Alexander
nexrad_chris
vince
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
