Cameras Logo
patricia jones Posted on Sep 27, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My vivitar f 126 camera will not turn on,have changed the batteries
Level 3:
  • Vivitar Master 19,187 Answers
  • Posted on Sep 27, 2019
Vivitar Master
Level 3:
Answers
19187
Questions
0
Helped
4338766
Points
82259
All digital cameras have an internal battery that you cannot change. When the battery fails you have to send the camera in for repairs.
My vivitar T028 camera wont turn on
i also have a Vivitar ViviCam t028 and i just changed the batteries and it wont turn on i was just about to empty the memory card but it wont turn on so i can't i don't know what's wrong with it.
I can't get the camera to turn on. I changed the batteries and now it won't come on. The batteries are in corretly.
The batteries may not be compatible with your camera. Choose rechargeable batteries that have a long battery life, but if changing batteries nor charging it to full power does not solve your problems, the best suggestion I could make is to return to the store you brought it in to have it checked out. I believe Vivitar ViviCam 8018 Digital Camera has a 3 year warranty, so please bring your warranty card as well.
2helpful
Vivitar 8400 will not turn on. When switching on,
This is more than likely a Manufacturing problem. A lot of Vivitar cameras have this problem as well as many others that are usually not the consumers fault. Just a glitch in the technology. I alone have gone through four Vivitar cameras in the last six months. The best thing to do is contact Vivitar directly. This is there website: www.vivitar.com It is best to see if you can find the number for technical support. To see if they can give you a refund or replace it for you. I hope this helps. -Richard
Vivitar not turning on
the batteries seems to have gone old, not giving enough power Vivitar.
replace the batteries and it should be ok.
2answers
Vivitar 7340 won't turn on even with new batteries
Could be a loose circuit board connection, could be bad contacts in the battery compartment. Your only hope is to try to clean the battery contacts with alcohol and a q-tip. Sometimes a baking soda solution works better for cleaning, but does not dry like alcohol. Try not to get liquids in the camera.
Vivitar 8320
just change the settings .....
Vivitar ViviCam 5100
if you arent using rechargeable batteries, sometimes the bateries, well most of the time, they arent even strong enough to turn it on
Can't turn on Vivitar 4345 digital camera
Searching google groups shows others with problems after attaching Vivitar cameras to PC's & then not working. The only fix seems to be leaving the battery out until the camera resets itself. If you can get to the setup menu then try the "default" option to reset the camera to factory settings.
Top Vivitar Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
