Home Security Logo
R
Robert Labrosse Posted on Sep 27, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Noma 052-7805-0 motion sensor security light which I installed at the front door. The problem is that no matter where the duration adjustment is set, the lights only stay on for 2-3 seconds.
Level 3:
  • The Master 19,187 Answers
  • Posted on Sep 27, 2019
The Master
Level 3:
Answers
19187
Questions
0
Helped
4339746
Points
82259
The manufacturer does not give any info on the unit. There are 3 adjustments on newer models and this model has very poor reviews.
5 Related Answers
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Nov 22, 2007
SOURCE: Microwave trouble
In most cases, this is a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer. You can find one here:
http://www2.panasonic.com/webapp/wcs/stores/servlet/vServiceLocator?storeId=15001
Anonymous
  • Posted on Mar 17, 2009
SOURCE: Motion Light doesn't work on switch
it sounds like you may have the switch and the motion sensor wired is series , in which case the motion sensor will only function if the switch is in the on position and give you no way to keep the light in a constant on position. if you where to wire the sensor in parallel with the switch the switch would act as a bypass to the sensor , which sounds to me like what you are trying to achieve .
Anonymous
  • 3 Answers
  • Posted on Jul 17, 2009
SOURCE: Dual Brite sensor lighting. Lights will not stay
I really don't understand why these lights are so failure prone and I usually return at least 8 out of 10 back to the store but I've installed a lot of them. If its Zenith brand the light may need to be reset by turning the power off at the switch or breaker for 1-2 min then back on. Then check the motion sensitivity dial if its maxed out turn it back and set it to 75% full also the photo eye may be getting light from the light making it think its daytime at night so try to reaim the photo eye if possible away from the light source that should fix most problems or 20% of them but if you still have problems return it to the store or ask for their advise. Hope this helps I've seen a lot of junk motion lights in my time they are troublesome at times.
Anonymous
  • 4 Answers
  • Posted on Jul 29, 2009
SOURCE: GE Simon XT panel lights window, door and motion indicators
The system is working as designed. If you arm both doors/windows and motions, but you DON'T exit the premises during the exit delay, the system will "downgrade" its arming to doors/windows only. The assumption is that you haven't actually left the premises and are at risk of creating fale alarms. This behavior can be disabled in System Configuration (though it may require the dealer access code to do it).
Try opening and closing a sensored external door (even if you don't go outside) during the delay after arming doors+motion and see if the motions don't stay active.
emissionwiz
Marvin
  • 85242 Answers
  • Posted on Mar 11, 2010
SOURCE: Light stays on saying door ajar when all the doors
the sensor is called the door ajar switch, it is a twist in switch that is located on each of the 6 latches in the truck, one for each door and 2 at the tailgate, anyone of these can be the problem, Ford can hook up a scanner that can read exactly which switch is bad, the switch is cheap, the labor time to replace them is the killer, the door panel and rear glasschannel must be remioved to get them out and the new one in.
My lift master GDo motion sensor lights quit working.
If the motion sensor lights on your LiftMaster garage door opener have stopped working, and the suggested method of using the three-button wall control didn't resolve the issue, you can try the following troubleshooting steps:
  1. Check the Light Bulbs: Ensure that the light bulbs in your garage door opener are not burnt out or loose. Replace them if necessary. Use bulbs that are compatible with your opener and within the recommended wattage range.
  2. Check the Light Socket: Inspect the light socket for any damage or corrosion. Make sure it's clean and securely connected to the opener.
  3. Test the Motion Sensors Directly:
    • If your garage door opener has safety sensors (typically located near the floor on both sides of the door), check to see if they are aligned properly.
    • Make sure there is no debris, spider webs, or other obstructions blocking the sensors.
    • Clean the sensor lenses with a soft, dry cloth.
    • Check the sensor wiring for any damage or loose connections.
  4. Adjust the Light Timer:
    • Some garage door openers have a light timer setting that determines how long the lights stay on after activation. Check the timer setting and adjust it if necessary.
  5. Reset the Opener:
    • Sometimes, resetting the garage door opener can resolve issues. To reset, unplug the opener from the power source for a few minutes, then plug it back in. Test the motion sensor lights again.
  6. Inspect the Wiring:
    • Examine the wiring connected to the opener and the motion sensors. Look for any damaged or frayed wires. Replace or repair any damaged wiring.
  7. Check for Interference:
    • Nearby electronic devices or fluorescent lighting can sometimes interfere with the motion sensor operation. Try turning off or unplugging nearby devices to see if it affects the sensor lights.
  8. Update or Reinstall the Sensors:
    • If the sensors are older or have been in place for a long time, consider replacing them with new ones. Follow the manufacturer's instructions for installation.
  9. Contact LiftMaster Support:
    • If you've tried all of the above steps and the motion sensor lights still don't work, it's advisable to contact LiftMaster customer support or a certified LiftMaster technician for further assistance. There may be a more complex issue with the opener that requires professional diagnosis and repair.
Keep in mind that garage door opener systems can vary, so consult your owner's manual for specific instructions related to your model. Always prioritize safety when working with garage door openers and their components.
Outdoor Noma motion lights not working
If there is power, neutral and ground at the light fixture. The fixture will need to be repaired or replaced. Both the lights and the proximity sensor need to be tested. How do you want to proceed? Please write back with information and questions. Good Luck.
Sep 30, 2018 • Cameras
Can the PnP brand 30w motion sensor led floodlight be set to come on permanently
The specific capabilities and settings of the PnP brand 30W motion sensor LED floodlight may vary depending on the model and design. However, in general, motion sensor LED floodlights are typically designed to operate based on detected motion and have a preset duration for illumination after motion is detected.
If you would like the PnP 30W motion sensor LED floodlight to remain on permanently, overriding the motion sensor function, you can try the following steps:
1. Locate the settings: Check if the floodlight has any accessible settings or switches that allow you to adjust its operation. This could be located on the fixture itself or on a separate control module if provided.
2. Disable or bypass the motion sensor: Look for an option to disable or bypass the motion sensor function. This might involve flipping a switch, pressing a button sequence, or adjusting a specific setting. Consult the product manual or contact the manufacturer's customer support for guidance on how to accomplish this for your specific model.
3. Connect the floodlight to a separate power source: If disabling the motion sensor function is not possible or practical, you can consider connecting the floodlight to a separate power source that provides constant power. This could involve bypassing the original wiring or using a separate switch or power outlet that remains on continuously.
It's important to note that overriding the motion sensor function may affect the energy efficiency and intended purpose of the floodlight. Motion sensor lights are typically designed to conserve energy by only activating when motion is detected, providing illumination when needed. Keeping the light on permanently may result in increased energy consumption and reduced bulb lifespan.
Always refer to the product manual or consult the manufacturer's instructions for the specific model of the PnP 30W motion sensor LED floodlight to ensure you understand its features and limitations.
Defiant 110 degree Motion Security light burns constantly all night. How to fix?
There should be three adjustments on that light.
1. sensitivity
2. Dusk level
3. Time out or duration
Check to see if 1 or 3 is set too low
I have a Defiant 180 motion security light that no longer stays on continuous but only blinks when activated.
Your motion sensor lights are supposed to give you a sense of security and peace of mind.
Instead, they're driving you crazy because they won't stop turning on and off, regardless of whether there's an actual intruder setting them off or not.
If your motion sensor lights keep flashing on and off, you should try:
  • Checking whether they're actually flashing on and off or just flickering
  • Adjusting the motion sensor positioning and settings
  • Adding "side blinders" to your sensor
Let's take a closer look at some of the ways you can stop false alarms from your motion detector lights.
If you're not up for any DIY troubleshooting,install the 6ya.com app we will be more then happy to help!!
First off, are they flashing on and off or just "flickering"? If the problem is that your motion sensor lights are flickering, you have a completely different problem than the one we're are talking about in this how to.
Flickering lights (lights that produce unsteady, rapid changes in brightness) are usually caused by one of 3 things:
  • A bad bulb
  • Bad connection between the bulb and the light fixture
  • Problems within the circuit
install the 6ya.com app we will be more then happy to help!! for more help on this problem.
So if you have a motion sensor light that flickers when it's on, we suggest you first try changing out the bulb. If this doesn't fix the problem you'll want to have an electrician check the circuit for bigger problems.
However, if the problem is that your motion sensor lights are false-triggering, continue reading below for some troubleshooting tips.
Adjust the sensor settings Most motion sensor lights have an easily adjustable sensor. This sensor "trips" when it senses a significant change in the level of heat within its vision (that is, an intruder moving within its view).
Now, if the sensor is positioned poorly or if the settings aren't set correctly, it may pick up heat from areas it shouldn't (for example, movement from branches, cars in street, etc.). Use the steps below to make sure your motion lights are positioned and set according to your needs.
Step 1. Move the sensor from "Operational" to "Test" mode. This switch is located on the bottom of the sensor and turns the light off after a few seconds, allowing you to test different settings quickly.
step 2. Make sure that the sensor is directly facing the area you want it to "guard." If you want it to pick up on movement within the driveway, make sure it's tilted down far enough to prevent catching movement from the street but high enough so that it isn't going off when the breeze stirs the flowers lining the driveway.
step 3. You can also check the bottom of your sensor for a "range" dial. This switch dictates the distance that your sensor will detect heat/movement. If it's set to "max", lower the range.
step 4. Adjust any animal immunity sensors. Some motion detectors allow you to choose a pets or animal immunity setting so that the detectors won't trip when pets or animals up to a certain weight pass by. First off, make sure that yours is on if you have pets or animals . Secondly, most pet or animal immunity settings allow you to choose a weight setting. Make sure yours is set to the weight that matches the animals likely to pass by the sensor's field of vision.
5. Reset your sensor to "Operational" mode when done.
If you've played with all of these settings but find that your motion lights are still going off when they shouldn't be, continue on to our next tip.
Try "side blinders" Every motion detector light sensor has a particular angle range. Most angle ranges are anywhere from 180 degrees to 360 degrees.
But sometimes, a sensor's angle range is too wide and is triggered by unnecessary movement, like tree branches swaying.
Try putting thin pieces of electrical tape on one or both sides of your sensors to narrow its field of vision. This can be a "trial and error" process as you experiment with various thickness of tape so be sure to put your sensor in "Test" mode first.
I Hope This Help's We Are Here To Help you!!
I have an installed PIR exterior motion sensing light, but no instructions on how to set the controls. Now, if it senses motion, it will stay on for hours.
the sensor has at least 2 knobs maybe 3. one show hands of a clock one show sun. one may show sensitivity. the adjustment is low to hi the wider the adjustment the greater the setting check out this picture on ebay for the icon.
https://www.ebay.com/itm/Outdoor-12M-PIR12V-PIR85-265V-Security-PIR-Infrared-Motion-Sensor-Detector-GF-/292078238929?var=&hash=item4401383cd1:m:mRSg-Rlk4nJMZJH-BiKb2gQ
good luck
My Defiant LED outdoor white Blade Motion Security stays on all night
You may need to set the parameters once chosen which means you need to hold the set button in for at least three seconds once you have selected your choices.i usually set new up in the house and then check the duration of the light before installing in situ.
Motion sensor light lights up during the day
Is this new installation, or old motion sensor that has malfunctioned? Add comment.
Motion sensor has adjustment dials.
Motion sensor that lights in day has probably gone bad.
Occupancy switch and motion sensor wire the same:
http://waterheatertimer.org/How-to-wire-occupancy-switch.html
Gene
h
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
4helpful
The light stays on for a long time although it shuts off (a lot more that 4.5 minutes). Can this be adjusted to be shortened? Where and how on the unit?
If you have one of the newer models the duration can be changed by holding in the lock button until the light blinks (about 10 seconds.) A single blink indicates that the timer is reset to 1½ minutes. Repeat the procedure and the light will blink twice, resetting the timer to 2½ minutes. Repeat again for a 3½ minute interval, etc. up to a maximum of four blinks and 4½ minutes.
If your opener has the motion sensor feature and a person enters the garage and walks in front of the door control the light will come on for 5 minutes and then shut off.
1helpful
2answers
Motion sensor disarms itself
the system is set up to bypass the motion if a door hasnt been opened during the exit delay. you can either open and close a door everytime you arm the system or if you have access to the installer you can delete option 52 and that will fix your problem
Top The Home Security Experts
vince
Paul Carew
Are you a The Home Security Expert? Answer questions, earn points and help others
