You need to determine the brand/model of hub and then search for parts diagrams or repair procedures. Hubs are not specific to certain bikes, and the hub may change on a model from year to year. Post a pic of your hub, especially any part with writing on it, on a BMX site, or go to a bike shop to ID the hub.
SOURCE: 1996 ford f250 4 wheel drive truck
Item
Part Number
Description
N800794-S60
Bolt, M16-2.0 x 50
N601797-S2
Bolt, Caliper Mount M12-1.75 x 30
2C150
Pin Assembly
2C357
Disc Brake Caliper
5
1175
Seal
6
3423
Bearing
7
3105
Front Wheel Spindle
8
4221
Differential Bearing
9
4222
Differential Bearing Cup
10
1190
Wheel Seal
11
1102
Front Disc Brake Hub and Rotor
12
1102
13
1197
Locknut
14
1B198
Lockwasher
15
1C245
Thrust Washer
16
35704
Dana Nut
17
2K004
Front Disc Brake Rotor Shield
18
2B292
Anchor Bracket
19
3130,
3131
Steering Knuckle
SOURCE: Rear wheel bearing diagram
The bearing is pressed in so you will have to carry the hub to a machine shop to have the old bearing pressed out and the new bearing pressed in once you have the hub off the car.
Process to remove hub is as follows (from the 1990 Miata Service manual)
Remove rear wheel, rear wheel brake caliper assembly (suspend with a rope), and disc plate.
Check for rear hub play with a dial indicator, if excessive play either tighten the locknut or remove hub and replace bearing.
To remove bearing bend up the locknut stake and remove axle nut - torque is between 159 - 217 ft pounds.
Now remove the hub, retaining ring, rear wheel knuckle, wheel bearing (if loose), dust cover.
Replace with new parts, locknut, dust cover, knuckle bushings and hub bolts (if worn).
Take knuckle with wheel bearing to machine shop and have old bearing pressed out and new bearing pressed in.
Assembly is reverse of the above.
I have personally found that by the time I pay a machine shop to do the removal and reinstall of the bearing and take my time into account it is less expensive to pay a good shop to do this work for me.
DIY information at Miata.net
SOURCE: i just need a diagram of the rear hub on a coaster brake bike
Park Tool's website has a bicycle repair section and it will tell you how to do it. HWOB was trying to help you out; he told you where to get the info. On the Park Tool website, top-right corner of the page is a link to Repair Help. There will be a picture of a bicycle that you can highlight parts on. Click on the FRONT hub and it will show you several options of hubs.
Hope this helps,
matt
SOURCE: KleenMaid Washing Machine shop manuals/repair instructions
There are manuals available but these only tell you about the parts of the machine and the different cycles etc. Its a workshop manual that you need and these are not discussed anywhere on the net, Im not sure these were ever produced.
SOURCE: Need Behringer V-Amp Pro repaired or find diagram & parts
my euro2442 is not prperli runing so plese send me your service center in india
