Verizon Fios states you need a filter for HP Printers HP states no all in one printers will work with Fios. spent hours on phone with both they blame each other, one minute I can send or receive fax another I cant states communication error. Fios states not enough voltage to pick up on fax line working intermittenly. Any help is greatly appreciated.
SOURCE: vonage and faxes
Only real solution I know would be to get rid of Vonage. All experiences with Vonage has left a bad taste in my mouth. Regardless of your broadband speed, Vonage uses open internet and is subject to network problems. Fax's require Real-Time communication/transmission control, which is, thus far, not available with Vonage.
SOURCE: Communication error
keep the window closed ok? that's more along the lines of the phone issues, than the fax machine itself..there are many ways to outwit the phone tree issues, but each number would need to be encoded directly.
solution?
get a dedicated inexpensive fax machine, or use efax.com
SOURCE: hp all in one fax dials but keeps getting no answer.
Hi Michelle,
Please check the following link to resolve this issue.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01502049&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN
Thank U
SOURCE: C6180 FAX UNABLE TO SEND OR RECEIVE
check the the phone line, The fax sinal need good clear. Surely,plug the phone-line is rigth line socket. If you do that all, the broblem is still happenning,need to change "relay" on moderm fax board.
SOURCE: 3055 fax not working, sendng or receiving directly
Below is a link to an HP tech site. They helped me with MY hp all-in-one. It turned out I needed to download a different driver from HP's tech website (the download is free) and that is probably what you will be doing, also. God luck.
