For a definitive answer contact the manufacturer of the Swiffer - Proctor and Gamble:
https://www.pg.com/productsafety/search_results.php?searchtext=Swiffer&category=msds&submit=Search
Best of luck
SOURCE: Can you use irobot Scooba on laminate floors?
they are suppose to be hardwood floor safe but maybe you should call the manurfacturer and make sure
SOURCE: Purchased 30 inch induction cooktop stove to
its ok to cut the laminate using the wood saw to fix the new one.be careful to cut the laminate.
SOURCE: Is it safe to use the Shark Steam Mop on laminate
You have to consult the laminate flooring manufacturer for the flooring that you have but usually it voids the warranty.
SOURCE: i have a Shark Steam mop and loved it for my
Normal
0
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";}
It works great on hardwoods and laminate floors...
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it may
not be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
heatman101
Hi Shaun:
Just a couple of things to try:
- Make sure the laminate is supported at both sides when cutting.
- Make sure the laminate is held firmly against the fence and deck when cutting.
- Do not "rush" the cut. Laminate is very hard and does not like to be hurried.
- Make sure that the correct blade (teeth) is being used.
- And yes, the blade has to be SHARP
First, you can get the exact visual design that you wanted
and it will cost you considerably less. Second, laminate flooring can be
installed above and below the grade unlike hardwood flooring. Moreover, the
laminate flooring is installed without using any nails or glue which make it
much easier to it yourself. Furthermore, laminate flooring is extremely
durable, easy to maintain and can be replaced easily.
