Konica minolta bizhob c452
If you have lost the Bizhub manual you can find it here
https://kmbs.konicaminolta.us/wps/wcm/connect/newweb/b6c3af14-17d2-40a0-9c96-de452ca7c836/bizhubHDDSecurityGuideC650_C353_751_501.pdf?MOD=AJPERES&CONVERT_TO=url&CACHEID=ROOTWORKSPACE.Z18_H0261AK0LG7QE0AE0BVQU730H1-b6c3af14-17d2-40a0-9c96-de452ca7c836-mJm5PTq
Testimonial: "Thank you very much David. Your answer to my question was very helpful to me."
SOURCE: konica minolta 2430
Most likely you received this message after a toner was replaced. Reseat the cartridge and restart the printer. If that doesn't work remove all of the toner cartridges manually and reinstall.
Turn off the printer and open the top cover. Follow the toner cartridge all the way to the right side of the printer (on the white part). You should see a hole that looks like a cross. Take a pen or key and push down on the black button in that hole. While you are holding it down rotate the toner cartridge towards you. You want to get the colored roller on the cartridge about 1/2in away from the metal bar that says "consumable reorder". You should be in a position to take out the toner. Let go of the hole and remove the cartridge. Repeat the steps until all of the cartridges have been removed.
Turn the printer back on at this point. You are going to get toner not installed messages on the printer. Open the top cover and the cyan tray will be in place. Shake the toner and install. Close the cover and let it cycle to the next color (black). Repeat the process until all cartridges are installed.
If you are still getting the error you either have a bad cartridge or the carousel that the toners sit in is damaged.
SOURCE: konica minolta problem
How to reset an F34, F35, or F36 code.
Solution:
To clear the code, perform the following:
1. Turn the machine OFF.
2. Enter the 25 mode, (turn the machine ON, while pressing the 2 and 5 keys).
3. Select 1: Software Switch Setting.
4. Use the arrows on the LCD to select dipswitch 3-1.
5. Touch the OFF key on the LCD to change the data to 0.
6. Press RETURN.
7. Power the machine OFF/ON to exit the 25 mode. PLEASE. NOTE;
THIS IS ONLY TO RESET THIS CODE ,IF IT CAN;T BE CLEARED THAN YOU NEED TO Replace the temperature sensor assembly
SOURCE: konica minolta EP2010 error code c05
I have a Konica Minolta CSPRO EP1054 (in the Middle East)
I accidentally plugged the EP1054 copier into a 110V outlet instead of
the 220V. Immediately the malfunction code (error code) of "C05"
appeared along with the "Call Tec Rep" indicator light (wrench).
I followed the instructions posted by "Soul Visitor" ... i.e., I found
the "Trouble Reset Switch" (not shown in the user manual) by opening
the upper back panel and pressing the small black button in the lower
right hand corner of the middle circuit board (green).
It worked perfectly!
SOURCE: Bizhub Konica Minolta - Error Code C1183
First check the alignment front and rear of the finisher, check the finisher exit guide rollers if the paper is exiting properly, open both rear and the front cover and check the lower gears attach is the up/down drive belt. that lower gear one might be broken by the pin slot.
SOURCE: How do I clear error message C-2558 for the Konica
tis error means abnormal tonder density in the balck image unit take the blacke image unit out and shake it while holding it level and put it back in the machine to reset the error code leave the machine on and open then close the front door
