Trying to change leaky cartridges on a model #4570 faucet in bath room. I have a cartridge puller and can get to the cartridge but can not pull the cartridge out of its place. I have used a needle nosed plyer but am not having any success
SOURCE: Milwaukee Sawsal Broken blade
Spay inside where blade fits in with PB BLASTER & let set a while. Maybe you will get lucky & the blade will fall out as it should. If not then it will have to be dissembled in this area. There are 2 BB's inside that fit into the small hole on the blade. They are forced in by a spring, be careful not to lose these. Also check the accuatator when you pull the finger release, make sure it is going all the way or it is not broken, Good luck.
SOURCE: Replacing Moen 1225 cartridge.
you will need a puller more then likely but what you can try is a little wd-40 lubricating spray
SOURCE: New MOEN 1222 cartridge leaks
remove it and carefully inspect it, you might have scuff'd up the rubber's on the cartridge when you inserted new one.clean out,look in hous'ing for any foriegn mat.etc .you may need another new cart.
SOURCE: how to remove the cartridge from my pegasus
remove handle , unthread collar , same with chrome body base . make sure water is turned off from valve
SOURCE: How do you remove the handle on a MOEN T 4570
Don't turn the handle, but turn the body counterclockwise until the handle falls off.
