SOURCE: Sony Bravia KDL-40W4500 turns off
This can indicate a problem with the high voltage circuits. Since this is a new set, it should still be under warranty. DO NOT open up the unit as that will void the warranty. Return the set or request warranty service. Note the 8 blinks when you request service as that should allow them to bring the correct replacement parts.
Keep us posted.
Dan
SOURCE: Sony Bravia kdl-46S3000 flashing red lights
Sounds Lamp is weak in this TV.
Please replace lamp and procedure is written in TV user manual.
SOURCE: Sony Bravia KDL 46", no picture, standby light blinks 4 times
Since the TV is still receiving power, the problem is going to be with the TV's mainboard. After you unplugged the TV and plugged it back in, you said the power light went out again, so I assume the standby light wasn't flashing again? The flashing standby light is indicating an error code so my suggestion is to contact Sony for service options regardless if there is a warranty or not because service is the only solution to this situation. Don't forget to provide them the error code or 4 flashes repeating.
SOURCE: My Sony Bravia Kdl40v300 will not turn on When I
sorry. Hope you still have a waranty. This is not an uncommon problem with the sony's. 99% chance that the panel went out. Could also be a balance board issue, but usually not. Call Sony for an authorized repair center
