Washing Machines Logo
Cindy Davis Posted on Sep 22, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Will the LAB2700MQ pedestal fit my washer WFW94heawo?
Level 3:
  • Washing Mach... Master 6,688 Answers
  • Posted on Sep 22, 2019
Cindy  Wells
Level 3:
Answers
6688
Questions
0
Helped
3532046
Points
21745
The LAB2700MQ will probably not fit the WFW94HEAW0. There are two pedestals listed for the WFW94HEAW0, see https://www.ajmadison.com/cgi-bin/ajmadison/WFW94HEXW.html?gclid=EAIaIQobChMI47bwhbjl5AIVCdbACh19lgPeEAAYASAAEgJOnfD_BwE . One is a 10" pedestal: XHP1000XW . Different Whirlpool washers have slightly different placements of the screw locations for connecting the washer to the pedestal. Using a pedestal that doesn't match the washer could lead the washer to be unstable and shift during the spin cycle.
I wish that I had better news for you.
Testimonial: "Thanks for the answer but I actually found a set on a resale site, bought them and installed them. They fit perfectly."
  • Cindy Wells Sep 27, 2019
    You're welcome. I'm glad that the pedestals that you found worked. Cindy Wells
1 Related Answer
ercupa190
ernesto cuadra
  • 12223 Answers
  • Posted on Jul 14, 2013
SOURCE: looking for pedestals of another brand that will fit samsung w/d
go to www.repairclinic.com and ask them
God bless you
What is the model number of the pedestal that pairs with GHW9100LW
The pedestal part number is shown in the manual for the GHW9100LW and depends on the cabinet color. The white pedestal is LAB2700MQ. See ManualsLib, https://www.manualslib.com/manual/509178/Whirlpool-Duet-Ghw9100lw.html?page=4#manual , for the other pedestal model numbers/color codes.
I hope this helps.
Remove pedestal from washer
Those washers are heavy! They have weights in them to prevent moving when spinning. Some use bolts through the bottom of the pedestal up through the washer and others use bolts down through the washer into the pedestal. Remove the bolts and lift the washer off the pedestal. You might need to get levelling bolts for the washer or check to see if the bolts are on the bottom of the pedestal. Make sure you get help to move the machine.
Just purchased a LG 8500HSA Mega Front Load Washer Special Order! What is the Pedestal Model Number?
Please check your model number. 8500HSA does not cross to anything on LG.COM.
Universal pedestals are for sale at Sears, Home Depot, Lowers, and Best Buy. The pedestal and machine will bolt together, that is, a bolt will run upward from the pedestal into threaded bolt holes in the bottom of the washer. If you can measure the distance from bolt hole to bolt hole on the bottom of the washer, you can check to see if the universal pedestal fits before you buy it.
Several months ago I took my front loaders off the pedestals. The pedestals were kind of nice for handling the clothes but about 40% of the time I spilled either detergent, bleach, or softener because the pedestal put the drawer too high for me.
Will a Frigidaire Front Load Pedestal for washer model GTLF2940ES0 Fit under other brand Washing machines?
Generally not. Most of the pedestals are build specifically for other brand machines.
Will LAB2700LQo pedestal fit my Kenmore model 110-47532602 or 1108752601
Even though the Sears brand is made by Whirlpool, the 110 series is an exclusive line. IT is not likely to fit. You will have to measure the base and mounting holes on the pedestal and the machine.
How do you lower the height on a LG washer and pedestal? It's too high by 1" to fit under my wall cabinets.
The pedistal has 4 leveling legs on the bottom of it you can adjust to a certain point. You may have to take the lefts off completely and if it still doesn't fit, you unfortunately didn't measure properly.
1helpful
How do you install whirlpool duet pedestal
Make sure that you get the pedestal designed for your washer. The white pedestal for the GHW9400P would be LAB2700MQ. (There are slight differences in the pedestals for different series washers. The holes in the base of the washer will not line up with the holes in the pedestal for a mismatched combination.)
First if your washer has been installed, uninstall it. You need to turn off the water. Then disconnect the power cord and (carefully) the fill hoses. Loosen the hoses first and then completely remove them. Drain the hoses into a bucket. Disconnect the drain hose from the back of the washer. Use pliers to squeeze the clamp to get the drain hose loose.
Pull the washer away from the wall. Cover the area behind the washer with cardboard and tip the washer onto its back (on the cardboard).
Pull out the drawer of the pedestal. Next snap the spacers into the holes on the top of the pedestal. (These are part of the hardware kit in the drawer of the pedestal.) Remove the shipping spacers from the front of the pedestal (behind the drawer). Remove the Philips head screw from the drawer slides and pull the drawer completely out (save the screws). Push the slides back into the pedestal.
Look at the washer and remove the feet if present. Partially install two of the hex head screws from the pedestal installation kit in the bottom holes of the washer. (These are at the center back of the washer if it is standing up.) Leave the screws about 3/8" from the bottom of the washer. Move the pedestal over to the washer and slide the keyhole openings of the pedestal over the two partially installed screws. Position the pedestal against the top of the washer and insert the remaining two hex head screws. Do not tighten completely.
Align the pedestal with the base of the washer on all sides. When it is lined up, tighten the 4 screws by reaching through the drawer opening of the pedestal. Bring the washer and pedestal back upright. Reinstall the washer (remove the packaging if this was a new install). Level (front to back and side to side) the washer using the pedestal feet (again reach through the drawer opening). Make sure that all 4 feet touch the floor. Tighten all 4 locknuts.
Pull out the drawer slides and reinstall the drawer. Reinstall the Philips screws. Close the drawer.
For pictures of the install, go to the Whirlpool support site http://www.whirlpool.com/owner_center . Search for your pedestal and get the installation manual. The direct link for the LAB2700MQ0 install is http://www.kitchenaid.ca/assets/pdfs/literature/Installation%20Instructions%20-%208537141.pdf .
I hope this helps.
I need to know if it will fit area of 52" high
You will need at least 53 inches. 14 3/8 for the pedestal, and 38 5/8 for the washer/dryer.
2answers
Vibration
Does it have runner pads on the leveling feet on the washer resting on the pedestal?
If so, and it still moves all over, you will have to fasten the washer to the pedestal with bolts and nuts. I had a GE that did the same thing. I finally laid them on their side, drilled out the holes to fit bolts and washers I bought from Home Depot. They really don't make that clear, do they?
Sirwriter
Top Washing Machines Experts
john h
