First, make sure that the printer is plugged in and turned on. Close the output tray extender and rotate the output tray clockwise to stow it in the printer. Open the front door of the printer by tilting it down; the door is just below the LCD screen. Open the cartridge access door by tilting it down; this is behind the front door to the right of the LCD screen. Wait for the cartridge carrier to move into the replacement position.
For pictures of the front door and cartridge access door, see page 79 (page 85 of the PDF) of the manual. HP has the manual on the product support page: https://support.hp.com/us-en/product/hp-officejet-3830-all-in-one-printer-series/7172321/manuals . The current link to the manual is http://h10032.www1.hp.com/ctg/Manual/c04724956 . The doors are also shown in the Setup poster but it isn't as clear.
I hope this helps.
SOURCE: I have HP Office Jet
Open the lid and uplug the power cord, then reach in there and give the whole carriage a little boost one way and the other, my photosmart 8450 does this once in a while and once I move it a little and plug it back in, it goes where it should be.
SOURCE: Hp office jet 4215xi how to check ink level
HI
you may get the ink levels in several ways,
1) printing a test page.
2)if you got HP solution Center with the software cd of the printer ans it is installed in the computer,you can easily check the ink levels there.
3)sometimes ink levels option is available in the priner drivers in the printers and faxes in the control panel.
4)right clik the printer icon and then goto properties and then you will find tabs to check the ink levels,it might be in the service this device under the maintenance tab.
Feel free to contact me if there's any query.
SOURCE: hp 6500 office jet refill
to refill 920:
1. If you have the plastic cap that covers the 9 mm. hole where you can see the sponge, then tape this cap to the cartidge with scotch tape. If not, use some duct/masking tape to cover the round hole.
2. Use the dry hypodermic needle to find the hole that will be found at the very center of the 920 label. With the needle, pierce the label.
3. Fill the hypodermic needle with 4 cc of ink.
4. Insert the needle 2-3 cm. into the hole made in step 2. Draw out 1 cc of air, then slowly force the 4 cc of ink into the sponge. Use toilet tissue to absorb any ink that might have escaped.
5. Let the catridge stand overnight (if possible) so as to allow the ink to evenly saturate the sponge. If not, insert it into your printer immediately.
Note: If you are going to refill catridges, be certain not to allow the sponge to dry completely. Thus, you might want to do step one immediately and to enclose it in a sealed sandwich bag upon removing an empty catridge from your printer even if you are not going to fill it immediately.
www.catherinecollege.net
SOURCE: hp 920 xl ink cartridge filling instructions anyone have them
to refill 920:
SOURCE: Black ink cartridge is full, but it does not print
It is more likely that you have a bad or damaged Smart Chip on your Black ink cartridge. Check out this site, it may be helpful adaptiveink.com
