You meant this
PPRH5 ???
its not a computer so moved you .
like all things , that use batteries,
check that battery terminals inside for corrosion
then load test the batteries.
so how old is it
when it last run ok.
or replace the batteries.
to charge the battery turn the inverter switch off page 6 in your manual.
if you don't know how test the batteries with a load tester
find a shop that can,
or buy new batteries, (test or buy , 2 choices)
Hi I’m having the same problem with this jump box and compressor. I don’t have the original charger to it. The alternate way to charge it is suppose to be with a extension cord directly to the plug in port that’s used for electric that’s not working. Using batteries to charge this particular box is not an option to my knowledge it’s a STANLEY RHINO 500W JUMP BOX AND COMPRESSOR
HELP???????
SOURCE: VTech 2651 base (2.4GHz) +3 phones - base not charging, has power
email me, i may have a bbase for you, put vetech phone base in the subject line. thanks
tim
my email [email protected]
SOURCE: how long does charge last for a stanley portable power station
It depends entirely on what you are using it for. If you are talking how long will it hold a charge on the shelf with nothing hooked to it, weeks if not months, but I would charge it once a month to be sure.
SOURCE: Can I recharge car battery with my stanley dps109 digital power station
Short answer is yes w/ the above caveats.
Testimonial: "Thank you. Going to give it a try."
SOURCE: How can I tell when my stanley 450 amp instant starting power station is fully charged?
I would suspect that the internal battery has reached the end of its life. Surely there is a green light to indicate when it is charged?
• IMPORTANT: This unit is delivered partially charged.
Plug into an extension cord FOR 40
hours before using.
You cannot overcharge the unit using the AC charging method.
• To recharge this unit, use only the supplied AC charging adapter.
• All ON/OFF switches should be in the OFF position when the unit is charging or not in use. Make sure all switches are in the OFF position before charging. Here is the instruction book:
http://ecx.images-amazon.com/images/I/81US%2Bom6xKS.pdf
here is the booklet.
