SOURCE: Can't get the surround sound to play the rear speakers and small front speaker
Sounds like it's just in 2 channel stereo mode, only 2 speakers working out of 5 and a sub, look for a selector switch for switching to 5.1 surround, as far as the no video problem try replacing the cable for the video connection.
SOURCE: Panasonic SC-PT660 digital in doesn't work
Select to suit the type of audio from the OPTICAL IN terminal on the main unit.
1 While in “D-IN” mode
Press and hold [—SETUP] to select “MAIN/SAP”, “DRC” or
“PCM FIX”.
2 While the selected mode is displayed
Press [up, down] to make the setting.
MAIN/SAP mode (Only works with Dolby Dual Mono)
MAIN, SAP§, MAIN+SAP§ (stereo audio)
§ “SAP” = Secondary Audio Program
Dynamic Range Compression
DRC ON: Adjust for clarity even when the volume is low by compressing
the range of the lowest sound level and the highest sound level.
Convenient for late night viewing. (Only works with Dolby
Digital)
DRC OFF
PCM FIX mode
PCM ON: Select when receiving only PCM signals.
PCM OFF: Select when receiving Dolby Digital and PCM signals.
[Note]
Audio that is input through the OPTICAL IN terminal cannot be output
through the HDMI terminal.
SOURCE: Which external speakers work with an Emerson 19" LCD digital TV?
Coaxial digital output is not a speaker-level signal, and you don't connect speakers directly to it. It's an output signal meant to feed an amplifier which takes that kind of input. You then connect the speakers to the amp and select the digital input, the same as you connect a CD player and select that when you want play a disc.
SOURCE: wont start. turn the key and nothing. all lights work, radio,
have u checked all the wire from the soinoid starter motor if ing nition lights come on put a jump lead from the startemotor possitive tothe battery and should start
