Drills Logo
Ed Jaskinia Posted on Sep 17, 2019
Can a 20V MAX 2.5 Ah Lithium-ion battery be used instead of a 2.0 Ah battery? What is the difference? Will the chargerthatcamwith the 2.0 work for the 2.5?
Brandon Cherry
Level 1:
New Friend:
  • Contributor 12 Answers
  • Posted on Oct 01, 2019
Brandon Cherry
Contributor
Level 1:
New Friend:
Answers
12
Questions
0
Helped
7821
Points
18
As long as they are the same brand
sparkycp
Level 1:
Problem Solver:
  • Contributor 19 Answers
  • Posted on Sep 25, 2019
sparkycp
Contributor
Level 1:
Problem Solver:
Answers
19
Questions
0
Helped
6845
Points
35
Yes. As long as they are both the same format. The only difference is the capacity of the battery. The 2.5 Ah will last longer than the 2 Ah will on a charge. The charger will work for both.
5 Related Answers
Ekse
  • 13435 Answers
  • Posted on Feb 17, 2009
SOURCE: I need to find the correct battery for my DC-T50
Hey,
available here
http://www.atbatt.com/digital-camera-batteries/b/panasonic/m/024-910001-10.asp
Thats just one place, there are many places who sell this battery.
Let me know if you need anything else.
Thanks,
Ekse
Anonymous
  • 8 Answers
  • Posted on Apr 25, 2009
SOURCE: explosion of a lithium ion battery
this is also called reverse charging.
Reverse charging, which damages batteries, is when a rechargeable battery is recharged with its polarity reversed. Reverse charging can occur under a number of circumstances, the two most important being:
  • When a battery is incorrectly inserted into a charger.
  • When multiple batteries are used in series in a device. When one battery completely discharges ahead of the rest, the other batteries in series may force the discharged battery to discharge to below zero voltage.
Anonymous
  • Posted on Dec 15, 2009
SOURCE: Milwaukee 1/2 lithium ion 18v drill not working
I have the same problem and its about a year old too.
Anonymous
  • 2176 Answers
  • Posted on May 12, 2011
SOURCE: One question please, I have makita cordlless
according to the schematic I saw yes you can and I think that you will be pleased with its performance, their operator manual even lists the weight of tool with this battery. Makita has a 1 year limited warranty on the Li-Ion battery that you might want to consider if you have the receipt.
Testimonial: "thanks"
ideaal
Pieter Vleeshouwers
  • 2029 Answers
  • Posted on Jul 21, 2015
SOURCE: I have 2 DeWalt Lithium-ion batteries Apprx. 4 years old, charged 3 times...won't charge now
Its also important if is the batterie 14,4 or 18 V there is an other safety circuit on the batterie that must have a little lower basic dc on it that will referenced on the loader , i have do a short loading 4 amp for about 20 seconds 12 volt DC battery charcher from a car. and then direct disconnect from the connecting wires and place direct in the normal Dewalt li-ion loader then you see its functional only Dewald batteries where made functionally, panasonic ,hitachi bosch or others you can better send the batteries to a service where arre special cadex charchers to get back the deep discharge protection , makita has modificated machines from 2 to 3 connector contacts.also to have a prior deep discharge protection the machine will stops earlier .
2answers
What are the battery possibilities for 40 volt MAX^ lithium trimmer edger 2.0 AH
Replacement Black & Decker LBX2040 Cordless Drill Battery
Type: Li-ion
Volt: 40V
Capacity: 2500mAh
Color: Black
Weight: 1250g
Dimension: 182.88 x 86.36 x 149.86mm
Please go to view more about this battery on http://www.drill-battery.com/buy.php/black+&+decker_LBX2040_drill+battery.html
May 01, 2021 • Garden
Battery 18V Lithium Ion
Yes. Even the 20v "Max" are just 18V Li-ion
Sep 07, 2017 • Drills
Battery compatibility : drill DCK277C2m and battery DCB205
No it only fits the models it is designed to fit. Go on eBay to check this.
Where can I get a wiring diagram for a Porter Cable20volt battery
images for Porter Cable20volt battery wiring
Power Tools - Porter-Cable
www.portercable.com/20Volt
Get Linked with the Power and Performance of the 20V MAX* system of tools. Powered by a lithium ion battery platform which delivers the performance and ease ...
Shop PORTER-CABLE 20-Volt Max Lithium Ion Battery, 2 ...
www.lowes.com/pd_472386-79992-PCC680LP_0__?productId...
Lowe'sPORTER-CABLE 20-Volt Max 1.5-Amp Hours Power... ... PORTER-CABLE 20-VoltMax 4.0-Amp Hours... ... PORTER-CABLE 2-Pack 20-Volt Max 4-Amp Hours...Missing: diagram
Torque adjustment collar very difficult to turn
try spraying some lube like WD-40 in the chuck as it is faceing up and let it set overnight it may got some moisture in it . hope this helps.
Any solutions to dewalt 20v lithium battery charger got wet shows blinking light as if its charging normal but not charging
High Performance Current Mode Controller doesn't work for you in the charger. According to the link, scheme.http://kazus.ru/forums/attachment.php?attachmentid=51161&d=1377505983
Top Drills Experts
ADMIN Andrew
ADMIN Andrew
john h
Steve Pack
Steve Pack
Are you a Drill Expert? Answer questions, earn points and help others
