Hi Touzon, what Steve tells you is correct, the Rechargeable pias are 1.2 volts and conventional Alkaline batteries, depending on the brand, arrive to deliver 1,555 volts and depending on the number of batteries, the difference is made every growing older
This is why your luminous candles flash
I hope you understood the comment
Greetings Franco Dosil
Hola Touzon, es correcto lo que te comenta Steve, las pias Recargables son de 1,2 volts y las pilas Alcalinas convencionales, dependiendo la marca, llegan a entregar 1, 55 volts y dependiendo de la cantidad de pilas, la diferencia se hace cada vez mayor
Es por esto que tus velas luminarias parpadean
Espero hayas comprendido el comentario
Saludos Franco Dosil
Use rechargable ones then!
SOURCE: Vector Sport Spot 1,000,000 candle power spotlight
6 Volts, here is info from site.
VEC127Y
VECTOR SPORT SPOT 1 MILLION CANDLE POWER CORDLESS-RECHARGEABLE SPOTLIGHT
SOURCE: Braun 5614 rechargeable cordless shaver light flickers
Your batteries are starting to degrade, but the good news is they're still holding a charge for a week, so you really don't need to rush to replace them at this point.
The flickering of the charged indicator is normal, as the shaver is still plugged in and the batteries are fully charged. The flickering is due to the batteries chemicals breaking down, and as such, the charge cycle keeps "topping" them off while it's still plugged in.
When you finally aren't able to get a decent amount of cordless operation and run times from your shaver, then you'll want to get them replaced, whether you decide to do that yourself or have it done by a professional service center, is up to you.
Here's a reference for your future use. www.electricshaver.com carries replacement (factory OEM) batteries for most brands of shavers and they also will provide the repair/replacement service for you, should you decide you don't want to do it yourself. You can also give them a call at 1-888-476-1785 and request a price quote, etc.
Anyway, your shaver is working fine and all you need to do is make sure you're not letting the shaver stay plugged in and charging constantly for more than a day, since any "extra" chargind isn't doing anything except keeping the batteries at a constant state of charge. Heat is a byproduct of charging and discharging any battery and as such, you want to allow for a cool down period before recharging them.
I tend to use my shaver until it is almost completely discharged before recharging it. By doing this, you can get the longest working life out of your batteries before you'll have to replace them.
Hope you find this Very Helpful and best regards!
Testimonial: "very helpful"
SOURCE: replacement battery for a Vector # VEC137R flashlight
You can order it from Black and Decker, Vector sold all their product lines to them in 2006 and they carry the replacement battery cheaper than anywhere else I found.
http://www.dewaltservicenet.com/Products/ProductDetails.aspx?pid=69262&tid=16032
SOURCE: how do i find charger for cyclops 15 million candl...
INPUT: 120VAC 60Hz 18W
OUTPUT 12VDC 1A.
This is the spec for the 18 million thor cyclops which i presume will be the same for the 15 million.
Red light on torch flashes while charging. As soon as full charge is done red light stays lit.
SOURCE: Where can I purchase a replacement battery for the
http://www.tempestbatteries.com/html/tr6-6.html
Flameless candles are made from beeswax like regular candles but instead of a wick they use Led lighting to illuminate the candle. They look very realistic but are much safer than regular candles.
