Just cutting over and over the same area
Go to
http://torrent-finder.com/open/36-Fulldls.com/%20update%20drivers%20
and use torrent to download the program
Use it to update any driver
Enjoy
[email protected]
SOURCE: cricut design studio software
I was recently told that as long as I have the serial #'s, I could download the program onto my new computer without having to re-buy it.
SOURCE: Cricut Expressions Machine error
Hope this helps you.
SOURCE: Just took my Cricut machine
The first and easiest solution would be to increase the cut pressure. Do this with the "Pressure Dial" found on the left side of the Cricut machine. The blade height may need to be adjusted, particularly if you are trying to cut through thicker stock. Refer to "Adjusting the Blade Height" in the Cricut User Guide. Click on the link below to view the user guide
http://support.provocraft.com/ContentPages/Home.aspx
http://support.provocraft.com/ContentPages/Faq.aspx?id=59&pageTitle=Frequently+Asked+Questions&guid=
SOURCE: WHen the cricut is cutting it tears my paper even
After having the Cricut for many years, I finally figured out how to cut the intricate cuts. Use multi cut 2, speed on med (3) and pressure on 4. I also keep my blade at 4. It takes a lot longer to cut but it cuts out good!
