SOURCE: Spots on tomatoes
There are also other things which can cause issue's like / Blossom end rot> caused by poor calciumuptake due to inconsistent moisture/ can use a soaker hose to keep constant moisture with mulch .
another could be two forms of "blight" "Late Blight" will affect fruits on vine > caused by fungus which is favored by wet weather. Will cause plant and fruit to suddenly rot if gets worst get rid of all affected plants .
avoid over crowding of plants allow good air flow between plants
While 'Early blight'/ is cause by fungus which survived the winteron old vines left in garden/ rotate crops to break cycle allow good air circulation get rid of any and all affected plants remove any foliage and disgard away from any material being used in garden
SOURCE: brown bugs on tomatoe plant--what can i do?
IF you don't want to use a commercial insecticide, you can drown them with mildly soapy water that you can spray on the plants. You can also use a cedar based oil spray like they offer on cedarcide dot com.
