Heating & Cooling Logo
A
Anonymous Posted on Sep 12, 2019
How do I unlock honeywell t6 pro series? It is locked in a scheduled program that we are unsure where it came from and do not know how to get it back to the manual operation. HELP!
J Rosado
Level 3:
  • Master 1,202 Answers
  • Posted on Sep 12, 2019
J Rosado
Master
Level 3:
Answers
1202
Questions
Helped
499861
Points
3432
A manual is what you need to unlock and reprogram the schedule. Keep off the set up steps for the thermostat, only the scheduling and security steps.
https://www.manualslib.com/manual/1189747/Honeywell-T6-Pro.html?page=8#manual
  • J Rosado Sep 12, 2019
    Take note of current settings before changing to a new setting, to revert, back step.
5 Related Answers
Anonymous
  • 3 Answers
  • Posted on Jan 05, 2009
SOURCE: wiring diagram to connect programmable Thermo to Heat Pump
I don't know if this will be helpful or not, but I just installed a new Honeywell and the Honeywell customer service guy helped me get the wires done correctly. The number is 800-468-1502.
Anonymous
  • 3 Answers
  • Posted on Jul 04, 2009
SOURCE: How to lock a Honeywell TB7220U Thermostat
With directions go to system. Then hold down 2 blanks on either side of middle for 30seconds this shows you Advanced settings . Read through and find the proper settings
Anonymous
  • 767 Answers
  • Posted on Mar 01, 2010
SOURCE: how can I remove the set program on my honeywell
Just set the temperature you want and then press hold and this will keep the temperature you want.
Anonymous
  • 742 Answers
  • Posted on Jun 18, 2010
SOURCE: I have an Acoustic Solutions TV model LCDWDVD19FB
If google and manufacturer website are of no help then ask a search agency like http://manualfox.com - They do a great job.
The service is not for free, but often worthy (you only pay if they find what you are asking for).
Michael Ulch
  • 48 Answers
  • Posted on Feb 26, 2011
SOURCE: White digital Honeywell Theromastat that is stuck
What model is it? example pro 5000, 6000, 8000 ext.
The model of honeywell, thetmastat is pro series
you need to download the t6 installation manual. enter the isu menu and set up the tstat to control a heat pump.
My Honeywell pro series thermostat has a caution flag on the display. What does that mean?
Do you mean the alert flag (a triangle with an exclamation inside it) or a different symbol? The Alert flag will appear with another message on the screen. If it is time to replace the battery, you'll also see "BATT" to the left of the flag and a low battery icon somewhere along the top of the LCD screen. If the thermostat is set to alert you to change the HVAC system filter regularly, you'll see "REPL" to the left of the alert flag.
This is from the T4 Pro thermostat manual on pages 6 and 7. See https://forwardthinking.honeywellhome.com/assets/tseries/resources/install/T4%20Pro%20User%20Guide%20-%2033-00188EFS.pdf . The T6 Pro uses the same alert behavior.
I hope this helps.
2helpful
2answers
Heat pump with Honeywell T6 Pro thermostat. It's programmed for 69 during day and 65 at night. But the Adaptive Intelligent Recovery causes the house to heat up about 90 minutes too early. Options
For the T6 Pro model, I found the installation manual; search for 33-00181.pdf. I pressed Menu and + for 3 seconds to get into Advanced Mode; then Select to enter ISU ("Installer Setup"); then Select several times to get to option 425 (Adaptive Intelligent Recovery). I then pressed "-" to make the setting zero (OFF); then pressed HOME to save the setting.
I have my new Honeywell Pro series thermostat running on the "schedule" I set. But now I want to leave town and set it on PERMANENT HOLD at a lower temp. I cannot find a HOLD button anywhere.
you must enter the installer setup by pressing the center button and the + button simultaneously for three seconds. press select on ISU. Option 120 is the programming selector. 0 is no programming meaning you would be OFF your schedule. Take note of what it is now, you will have to do the same thing over again and change it back when you return. You can find all this info in the manual, best wishes.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
My Honeywell T6 thermostat is locked and I cant unlock it?
Honeywell Customer Care toll-free at 1-800-468-1502. I read the owner/installation manual and there is no explanation. Try Honeywell direct. Have the model number when you call, located on the back of your t-stat. Hope this helps!
6helpful
Permanent hold message on thermostat
press run program.... from there, set the schedule for maximum efficiency. permanent hold only shows up after the hold button has been pressed 2-3 times. If this does not fix the issue, there is a master reset button on the thermostat that will set all settings back to factory default.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/cody_17f08cf8e340c06c
Honeywell VisionPro TH8000 touch screen will not allow changes to the schedule. Screen is unlocked and not in cleaning mode
In the set up mode are you sure the lock was not turned on. The set up mode has a different book for the installer. Do you have the book if not check with Honeywell or let me know.
Top Honeywell Heating & Cooling Experts
Paul Carew
john h
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
