SOURCE: hobart engine drive welder has no power out put
i took an old trickle battery charger,6 volts and energize the armmiture,all so called polarizing,google it ,shows how also
SOURCE: Generator stopped producing electricity
if the generator has been sitting for a while you might have to excite the magnets to start producing power. plug in a reversible drill and with the generator running turn the drill in the reverse direction by hand while holding the trigger in the forward position.
SOURCE: Rv Generator does not put out any ac power, but cranks great
could be a bad transfer switch.
SOURCE: I have a Hobart 135 Handler wire feed welder that
Get a volt meter, go to ohms setting , check transformer to ground for low to zero ohms reading. also look closely at transformer windings for foreign objects in between them, never know what you my find. If transformer is shorted to ground probably time to say some nice words over it before burial. Also just for kicks try a new gun on it, (there is a reason i'm asking you to do(this) see if you can find someone that has spare. A good honest repair shop would probably be reasonable if all else fails. to a least let you know if the transformers a problem. good luck
Signed
Former Miller Certified Tech.
SOURCE: main power switch is broken. I have to turn the
Any local Airgas shop should be able to get you one or take the switch to Grainger and see if they can get you a replacement.
Indicates an open in the thermal protection circuitry located on
the rectifier assembly of the unit.
Help 11 Display
Output Selector switch is not in correct position
I found the manual for your machine. https://www.red-d-arc.com/pdf/D302K3-12%...
Thanks James
I have the same machine I have no welding power how do I jump start the big brushes where do I touch the cables too also only getting volts amps won’t adjust any ideas !!!
