My printer is displaying Epson Error Code 0x97. What it mean?
As innovation going propelled, contraptions like PC, printer, workstation upgraded their productivity. You can complete any undertaking work in a moment. There are numerous printers accessible in the market, yet Epson printer is best from every one of them. Due to its strength and availability. Once in a while, client face issue with Epson printers like Epson Printer Error Code 0x9a, or Epson printer not printing, and so on.
Visit: https://www.epsonsupports247.com/simple-steps-to-fix-epson-printer-error-code-0x9a/
How to fix Epson Error Code 0x97?
When a hardware failure happens without warning, you can try the following:
Unplug and Plug-in
When this error message appears. Turn on off power and unplug.Unplug all connected cables.Unplug USB drivers.Remove all printer cartridges.Still turned off, press down power to release all remaining current in the printer.Plug in all cables and USB. Reinstall printer cartridges. Turn power on.See if the error message remains.If error persists, continue to the next method.
Unplug and plug in (2)
Turn off Epson printer and unplug.Disconnect all cables and USB.Wait for 5 minutes until printer cools down.Press and hold the power button for 60 seconds. DO NOT RELEASE.After 60 seconds (DO NOT RELEASE), plug in power cord and hold for another 60 seconds. Release power button. Check if error message still appears.
Clean Mechanic Pad
Turn off printer and unplug.Remove printer cover and casing.Wet tissue with warm water. Wipe cleaning pad.Leave wet tissue for a few minutes on the pad.Remove tissue and leave it to dry completely.Plug in and turn on printer. See if error persists.
If all methods are tried without improvement, you might need to call the customer support or help of a technician.Epson XP-830 is a multifunction printer that has a complex interior hardware. Therefore, a professional help is needed when all methods were tried.
SOURCE: EPSON DFX 8500 ERROR CODE E5 THEN POWERS OFF
It would sound like a defective encoder sensor, almost ANY copy repair shop can fix this for you, you can try to buy the manual and fix it your self but that is NOT recommended
SOURCE: HP LASERJET 4 PRINTER
57 (or 57.1) SERVICE Message (Main Motor
Failure)
The 57 SERVICE indicates that the DC Controller PCA detected a
general motor failure. The Main Motor drives all moving
components in the printing process. The Main Motor is a 4-phase,
DC servo motor controlled by the DC Controller PCA.
The formatter detects a Main Motor failure when:
• The Main Motor does not come up to speed within one second
of receiving drive voltage.
• The Main Motor deviates from the correct speed for one second
after reaching the correct speed.
Main Motor Functional Checks
• Inspect the gear train for debris that would block the free
operation of the gears.
• Check the gears in the Toner Cartridge for wear and binding.
• Reseat J211 (or J214 on the HP LaserJet 4 Plus/4M Plus) on
the DC Controller PCA, and the main connector on the Main
Motor Assembly. Refer to Figures 7-16 and 7-17 for the DC
Controller PCA connector locations.
• If the problem persists, check that the +24B Voltage is present
on the DC Controller. If the voltage is not present, replace the
DC Controller. If the voltage is present, and the motor does
not rotate, replace the Main Motor Assembly
SOURCE: have changed the black ink in the printer as it
Error E5.
Cause : The FINE Cartridge may not be installed properly or the Cartridge may not be the compatible with the machine.
Action : Install the appropriate FINE Cartridge. If the lines are misaligned or the resulting output is not satisfactory, carry out the FINE cartridge Alignment.
Replacing A FINE Cartridge.
When replacing a FINE Cartridge, check the model number very carefully.
The machine will not print properly if the wrong FINE Cartridge is used, or installed incorrectly.
Black : PG-40 Black
Color : CL-41 Color
The FINE Cartridge PG-50 Black (High-Yield) and CL-51 Color (High Yield) are also compatible with this machine.
When a FINE Cartridge runs out of ink, replace it using the following steps.
1) Ensure that the machine is turned ON, and then open the Scanning Unit. The FINE Cartridge Holder moves to the left.
Pull the Scanning Unit Support down into place.
2) Remove the empty FINE Cartridge.
a) Push the FINE Cartridge carefully to avoid staining your clothes or the surrounding work area.
b) Remove the FINE Cartridge.
Important : * Handle FINE Cartridges carefullu to avoid staining your clothes or the surrounding work area.
*Discard empty FINE Cartridges according to local laws and disposal regulations.
Caution : Do not touch the transparent film, film cable, ink absorber (sponge part) or any metal parts.
3) Prepare a replacement FINE Cartridge.
Unpack a new FINE Cartridge and remove the Protective Tape.
Important : * Do not reattach the Protective Tape once you have removed it,
* Handle the removed Protective Tape carefully to avoid getting your hands dirty or staining the surrounding work area once you have removed it.
* Once the Protective Tape is removed, do not touch the gold terminals of the FINE Cartridge or its nozzles. The machine may not print out properly if you touch the terminals.
4) Insert the new FINE Cartridge.
Black FINE Cartridge should be installed into the left holder and Color FINE Cartridge should go into the right holder.
a) Insert a new FINE Cartridge on a slight tilt.
b) Push the FINE Cartridge up until it clicks into place.
5) Close the Scanning Unit.
Lift the Scanning Unit slightly and put the Scanning Unit Support back to its original position,
Then close the Scanning Unit.
The FINE Cartridge Holder moves to the right.
Note : IF the straight line is misaligned or the FINE Cartridge position is misaligned, align the FINE Cartridge position.
Important :
* To maintain optimal print quality, we recommend that you use Canon brand FINE Cartridge. Replenishing ink only is also not recommended.
* Replace the FINE Cartridge runs out of ink, replace the FINE Cartridge with a new one immediately. If you replace it with the FINE Cartridge that has previously been removed, the machine may not print properly due to clogged FINE Cartridge nozzles. Furthermore, the Low Ink Warning dialog box which advices when to exchange the FINE Cartridge will be inaccurate.
* To maintain optimal print quality, use up all the ink in the FINE Cartridge within six months of its first use. (We recommend that you note the date that the FINE Cartridge was installed in the machine.)
* Color ink consumption may occur even when black-and- white or gray-scale printing specified.
Color ink is consumed during Cartridge cleaning, which is necessary to maintain the machine's capabilities.
Aligning The FINE Cartridge
If ruled lines are misaligned or a printout is unsatisfactory, FINE Cartridge Alignment is required,
* Aligning the FINE Cartridge
1) Press [Maintainance] repeatedly until <P> appears.
2) Press [Black] or [Color].
The machine prints the head alignment sheet.
3) Beginning from Column A on the printout, enter checkmarks in the patterns that have the most solid image.
4) Load the checked sheet on the Platen Glass.
When loading the checked sheet, place the front side down, and align the upper left corner of the sheet with the alignment mark on the lower right corner of the Platen Glass.
5) Press [Maintainance] repeatedly until <U> appears.
6) Press [Black] or [Color].
The machine scans the pattern and aligns the FINE Cartridge automatically.
Note : If you select <L> in step 1, the machine prints the current FINE Cartridge Alignment setting.
Hope this helps.
Please rate my response
Thanks.
Have a good day.
SOURCE: my epson tx100 printer scanner
try to update the firmware of the printer.
Use new cartridge DO NOT USE REFILLED INK.
SOURCE: What does printer error code 5800 mean?
This is an ink overuse error. It may read 5B00 and not 5800.
No real easy fix as far as I know but this video might help. Good luck! https://www.youtube.com/watch?v=0waX_GF-h7U
This video might help
Testimonial: "The procedure described in the You Tube video worked fine up to the point I should have received the LED screen directions to download two pages. My LED screen only contained "Service Mode" and "idle". I tried several times to obtain the download instructions screen, but it never appeared. Huby"
