Washing Machines Logo
Michael Norsavanh Posted on Aug 25, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My frigidaire fex831cs stackable washer and dryer is have trouble working. The washer is the problem, I have started a cycle to wash clothes and it has stopped mid cycle with water filled up and clothes still in there. Can someone help me ASAP! Thank you!
jcb93
Level 1:
Problem Solver:
  • Contributor 8 Answers
  • Posted on Aug 25, 2019
jcb93
Contributor
Level 1:
Problem Solver:
Answers
8
Questions
0
Helped
1052
Points
18
It can be either of these 3 problems. The easiest one to check is the door lock, open and close the door. You might even have to do this a couple of times before the cycle starts up again. The second one is the water inlet valve, and the 3rd is a drain pump failure... you could have a sock stuck in it. Both the 2nd and 3rd problems, you need to pull the washer apart to fix. These two vids might not be your exact model but it will be a good guide to use. https://youtu.be/pxwD5SieFP0
https://youtu.be/0DoQPHTt4Ig
mike simpson
Level 3:
  • Master 717 Answers
mike simpson
Master
Level 3:
Answers
717
Questions
Helped
161815
Points
2252
Try going to another setting on the dial like heavy or delicate and spin the dial from start and click to almost the end of wash cycle and start. the pump should start draining. If not your may have to go a few clicks less or more just spin around again. If it does not pump out then it could be a clogged drain line or bad pump
Mike .
5 Related Answers
Anonymous
  • 1294 Answers
  • Posted on Jan 06, 2008
SOURCE: washing machine stops mid-cycle and full of water
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Anonymous
  • 351 Answers
  • Posted on Mar 02, 2008
SOURCE: hoover 600mb 6.0 kg top load washing machine (not as below)
timer or timer module fault
Anonymous
  • 8619 Answers
  • Posted on May 29, 2009
SOURCE: stops in the middle of wash cycle
Hi!
If the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Anonymous
  • Posted on Jun 11, 2009
SOURCE: mle2000ayw Stackable washer/dryer not washing, spinning
If the door lock light is on then is might be the "door lock enable spin switch" the plunger at the opposite end from the wax motor is not fully depressing the switch. In the stackable it is just behing the door lock. Remove the two middle covers (2 white phillips screws and one hex head screw on the middle of lower cover by the wires)to test place a few layers of masking tape on the end of the plunger and cycle the machine. Might also be a weak Wax motor (dark brown in color) to be safe replace both for about $12 each. Fix in 10 - 15 min.
graemevm
Graeme van Malsen
  • 519 Answers
  • Posted on Apr 18, 2010
SOURCE: Kenmore Stackable washer/dryer Model #11088752793, won't heat
Either the elements have blown, or it could be a device called a thermal overload which has popped. (There may also be a loose wire which connects to the heating elements). Have your drier checked out by a good handyman or technician.
Best wishes,
Graemevm
Just bough a used frigidaire stackable unit model FEX831CS and washer makes extremely loud noise on spin cycle. and dryer takes over 2 hours to dry a regular load of clothes. Please help
Hello uucyc1 - From what you have described it sounds like you either have a problem with the washer tub bearing, belt, motor or trunnion (steel bar that secures the inner basket to the transmission shaft). As far as the dryer, long dry times typically are a result of poor air flow. Make sure that the dryer exhaust vent is completely clear and that the unit is not overloaded. I would suggest contacting an experiencing service technician to determine the precise cause to both units.
I have a stackable Frigidaire washer/dryer combo and the problem is that when you push the start button, you hear an electrical buzzing but the dryer won't start. When you take the panel off it st
Hello Mike Brady - From what you have described it seems like the dryer is experiencing a wiring failure or a communication error with the control board. Contact a professional to move forward accurately.
Won't fill with water and goes right to wash cycle
Chech the pressure lelvel switch and hose that is connect to the pressure switch and tub
Need belt for stackable frigidaire washer and dryer. Model is FEX831CS The washer jerked and threw a breaker. Now the dryer won't work and the washer lets water run in and the inside starts jerking hard
If you think that the washing machine belt is the cause of your troubles you can find it in the very bottom of the machine (behind the front panel)
Would need more info on the dryer problem, (Is it running with no heat or not running at all)
the washer drive belt is the only easy fix on this model.
Good Luck
Quentin
STACKABLE WASHER/DRYER DISASSEMBLY
FLSE72GCS6 this model number is showin as a complete laundry center, not 2 seperate peices. in which casse there is no seperating them
Top Frigidaire Washing Machines Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
