Welding Tools Logo
Tom Kelly Posted on Aug 25, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Does the cooling fan in my 225 Lincoln welder usually run continually..?
David Soto
Level 2:
  • Expert 414 Answers
  • Posted on Oct 05, 2019
David Soto
Expert
Level 2:
Answers
414
Questions
Helped
193634
Points
758
Yes, newer models have fan on demand.
5 Related Answers
Anonymous
  • 225 Answers
  • Posted on Jun 18, 2009
SOURCE: cooling fan/ lincoln 225 arc welder
the fan should be pulling air from the front of unit and out the back.
Anonymous
  • 225 Answers
  • Posted on Aug 02, 2009
SOURCE: ARC 225 - Can't hear fan.
sounds like you lost one leg of power to the unit,check power source and the the plug on the welder.
Anonymous
  • 474 Answers
  • Posted on Nov 11, 2009
SOURCE: Need wiring diagram For Lincoln Welder
try the company web site
Anonymous
  • 6 Answers
  • Posted on May 04, 2010
SOURCE: Where do I find a replacement cooling fan for a
I took my old one to Grainger and they ordered a new one that is 230V. Total cost of motor and fan $27.00
Anonymous
  • 6 Answers
SOURCE: how do you wire the old lincoln 225 ac welder
What are you wiring? Power Cord? Fan? Transformer? You should see a white wiring block in the lower right corner if you are looking from the back. On the two top post the black and white wires are attached. The green ground wire is attached to the case. On the two bottom poles the fan lines attach one on each side and the transformer wires that are coming up from the transformer are attached on the same poles as the fan wires.
Lincoln electric ac/dc arc welder will not arc
Check the dial indicator. Sometimes if someone changes the amps while welding, there will be a break in the coil. It will work at a different setting as long as you are away from the break.
3helpful
My AC 225-S welder is missing the wiring diagram. The cooling fan wires are pulled apart. Need to know if the fan is 110 or 220 and where to put the wires back. Billy Lynch
Fan Motor MOTOR
2910.0
230.0 AC
Here is a Picture of the wiring Diagram that should be on the inside of the rear cover If this is hard to read Here is a link to the original
I need to find parts for my welder lincoln the fan coolin is not working
Any welding supply house can either get you a fan, or direct you as to where to find one locally.
--W/D--
Coming out of the breaker box going to the welder plug what size wire should i use to run a lincoln 225 welder
It depends on how far away you are going to be away from the breaker box, using a #2 wire should be fine for your welder.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/matt_8dbc24bf722649ac
Whats making the fan on my welder not work
The fan motor has probably burnt out, i see this alot...make sure the connections are good....you can try putting 120v to it directly, if it doesnt run you need a new one...if it does then you need to check all your connections
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
3helpful
Need the diagram for an old welder, ac/dc 125/225 need to find out how to hook the fan up
Usually the fan if it is, 112/225V. It simply connects across the Line, Phase to neutral, but AFTER the mains switch. So that it is "On" only after the Power has been switched on.
3helpful
Where do I find a replacement cooling fan for a lincoln 225 stick welder?
2helpful
Cooling fan/ lincoln 225 arc welder
Top Lincoln Welding Tools Experts
Sean Wright
Sean Wright
vince
Are you a Lincoln Welding Tool Expert? Answer questions, earn points and help others
