SOURCE: Hitachi 42HDS69 42 in. Plasma with red lines
I think you have dry solder joints on the tv. Either on the chroma board, the vertical scan board, the line output board, or on the focus board. If you are going to do this yourself please take all necessary precautions against electric shock and discharge all capacitors that you can as a stray spark from one can cause damage to your tv and yourself. If you are not able to do this find a competant technician. Good luck.
SOURCE: problem with philips 42 inch plasma tv
if you go and download the new firmware it will take care of the red light problem. firm ware upgrade version 1.5.0.0
SOURCE: Red Error light
check the filters caps in the power supply board that could be your problem
good luck
[email protected]
SOURCE: my 42 inch venturer plasma tv wont turn on. it is
Your set may have a main fuse located inside the back panel.
If it doesn't, you have joined the ranks of those whose power supplies have failed way too early.
It may also have shut down to protect itself from a line surge so try pulling the AC plug out and ignoring the set for a few hours before plugging it back in.
I suspect your warranty expired already - this is a consequence of importing all of our electronics; when it breaks, we have no US manufacturer to turn to.
Sorry-
SOURCE: 50" phillips plasma wont turn on
I'm having the same problem and am about to try this solution. I truly believe this is going to work. I hope this helps!
http://www.youtube.com/watch?v=OsJSzYVUWVA&feature=related
Visit the site named 'Electro-help' for more
details. Click this link. View it in
"Timeslide" or "Flipcard" option, which can be selected
from the drop down box menu by the [Sidebar] tag, at the top left corner
of the display window. You can also
click the [Home] tab to see the latest updates. It will make search
easy. There are more than 1350 posts to different brand TVs now. Pull up older
posts there or do a search by type in the Brand Name of your device in
the Search Box, at the top right of the display window.
any ideas?
