Refrigerators Logo
J
Jackie Adams Posted on Aug 22, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What # should my Maytag freezer be set at? It has an ice maker with a bin but not a water dispenser. There is water leaking under the unit.
J Rosado
Level 3:
  • Master 1,202 Answers
  • Posted on Aug 22, 2019
J Rosado
Master
Level 3:
Answers
1202
Questions
Helped
500665
Points
3432
There may be a drip tray under the fridge, it needs to be checked and position properly
5 Related Answers
Anonymous
  • 12 Answers
  • Posted on Mar 10, 2008
SOURCE: Ice Maker leaking water in freezer and won't stop making ice
The filter should be before the fridge and should not affect it it sounds like the water valve from the fridge is defective .Other possibility is the icemaker head is defective and needs changing.
A
Anonymous
  • Posted on Aug 11, 2008
SOURCE: GE top freezer ice maker leak
I have the same problem -
Anonymous
  • Posted on Jul 03, 2009
SOURCE: leaking fridge
my maytag had cloged defrost drain cleaned drain all ok
Anonymous
  • 71 Answers
  • Posted on Apr 01, 2010
SOURCE: water leaks into ice maker bin
2 possible causes. 1) tehe tube is not inside of the ice maker. 2)the ice maker has acrack. better to call a tech
Sea Breeze
John Tripp
  • 4656 Answers
  • Posted on Apr 19, 2010
SOURCE: Ice Maker leaks water inside the freezer
I see you said you looked and the water valve is off but the only that I know of this happening is a defective water control valve. Like a dripping faucet that when off slowly drips until the ice forms and then one the ice maker dumps ice and tries to refill the water goes in every direction. Unplug water valve to confirm what I am saying, Tell me if it continues to leak. Sea Breeze
Why is Ice forming under and behind bottom plastic bin on freezer side?
The defrost drain is clogged or the icemaker drain line is frozen
Ice maker drips water into freezer.Makes ice but doesn't shut off when full.
How to Repair a Refrigerator Ice Maker ' HomeTips
www.hometips.com/repair-fix/freezer-ice-maker.html
Aug 6, 2015 - If the ice maker doesn't make ice but you can see the arm swing intomotion and you hear a ... 4Check the water line that enters the back of the freezer for a blockage. Find the water shut-off valve behind the refrigerator or under the sink, turn it off, ... If your ice maker keeps making ice, even when it is full:.
Refrigerator's Ice Maker Leaking Water ' ThriftyFun
www.thriftyfun.com/tf37813274.tip.html
If your refrigerator ice maker is leaking water, the first step is to locate the source. ... Its not the ice maker - in the floor of the freezer is a small drain that lets the ... I shutthe water supply off but water dispenser still leaks even though no ... My side by side refrigerator leaks water into the ice bin when filling the ice tray with water .
Maytag bottom freezer dispensing water but not making ice
there generally is a diverter that sends water to the ice maker and to the water dispenser as needed....such as when you ppush the plunger for water or the icemaker senses it needs to befilled with water.....either the unit is not working or one of the lines to the ice maker is eithr brokenor frozen ,,if broken you should see a water leak...ii have known people that take a hair dryer to try to un freeze a line....orcut off the unit for a while and defrost...before calling anexpensive repair person
1helpful
Ice maker makes ice but freezes before it can be dispensed so the dispenser is always clogged with frozen ice. Cleaned out the ice maker and started over but same results. The temp is set at 38 for the...
Hi, The freezer should be "0", the possible clogging you have could be a leaking water valve or an over filling ice maker. I would have the ice maker checked for volume of water dispenser during harvest, should be 5.5 oz. (2/3 cup), if more the 6 oz. the ice maker is bad. If fails to stop filling or leaks/drips, replace the water valve behind the unit.
I hope this helps.
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
1helpful
2answers
Water leaks out of freezer door where line is routed through when water dispenser is depressed. The water/ice through the door and the ice maker doesn't work either
well it could be a couple of problems depending on where exactly the water is coming from ill give you a troubleshoot for each and you can decide which is best depending theese are all directly from maytag
My refrigerator ice maker's fill tube leaks. How can I stop it?
First, check to make sure the clamp on the tube is tight.
Then, check to make sure the fill tube inside the freezer at the ice maker is not frozen. If it is, try using a hairdryer to thaw the tube.
Finally, check to see if the water pressure is too low. It should be at a minimum of 20 psi. For more information or assistance, please contact an authorized Maytag service provider.
My refrigerator's water dispenser is leaking. How can I stop it?
Try checking the connection at the bottom of the freezer door to ensure the nuts are tight.
Next, check lines going to the water reservoir to make sure the connections are tight. You'll find the connections in the back of the unit behind the black sound damper.
There's a leak underneath my refrigerator. What's causing it?
There are a couple of things you should check. First, make sure the tubing is tight and not cracked.
Then, check to make sure the drain pan is in place and not cracked or broken.
If these tips don't help you find the source of the leak, please contact an authorized Maytag service provider for more information or assistance.
There's a leak inside my refrigerator. What's causing it?
First, check to make sure the door is closing and sealing properly.
Next, check to make sure the fill tube connected to the ice maker is aligned properly and isn't letting water splash.
If none of these steps corrects the leak and you discover the water is coming from the fresh food sealing, you'll probably need to have the defrost pan checked. For more information or assistance, please contact an authorized Maytag service provider.
they are all pretty much along the same lines hope your eyes aren't bleeding from the laundry list here but it seems you should check the connections from the hose and the psi it sounds like your problem is related to a lack of pressure which would explain why water is not coming out and seeing as you have a visible leak would lead me to believe the pump is working correctly
Hope this helped
sorry if its long winded
please leave feedback
Robb
My maytag is model MFD2560HES serial number
does the water dispenser work OK ? if yes , a try this : pour 3/4 of a cup of water into the ice maker, right into where the ejection fingers are. also , take all of the ice out of the ice bin. then , give the freezer time to freeze the water you have poured into the ice maker and see if the ice maker ejects the ice into the bin. if it does, it might reset itself and refill the unit and work normally.
Ice maker quit qorking
The chute where the ice drops through could be icing up, try removing the I bin and cleaning the ice build up out.
Whirlpool side by side (ED5VHGXMB10) Not ejecting Ice
take and power off the unit for 5 seconds and then see what happens,
1helpful
Refrigerator leak
the water fill tube for i/m is on the back of ref. the tube you have is to the water dispenser. look in freezer floor, is it full of ice? if so, remove all ice and clear drain hole for evap. if not, reassemble what you took apart and inspect tube under ref. while someone runs water dispenser. find leak and repair.
Top Maytag Refrigerators Experts
vince
Johnny 1000
Jesse Walters
Jesse Walters
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
