Amana top load washer fills, washes, agitates, but will not automatically move to spin cycle -- the light returns to "wash". If we turn off, then turn on, then manually turn the cycle to spin, it does mechanically spin. So this is not a physical problem with belts etc. but some kind of cycling / switch problem presumably.
SOURCE: Maytag Washer Getting stuckon wash cycle
the possibility of it being the timer is most likely..as the rest of the cycles remain ok.. if you require a timer,you can get one here at this link..(click the link here) http://www.easyapplianceparts.com/AdvancedModelSearch.aspx?ModelNum=HAV4657EWW&mfgModelNum=&fkMfgID=1
please be aware that you will need the machine serial number in order for them to issue you with the correct part/s you will require.. parts are cross referenced with the serial number.
these diagrams will also enlarge in order for you to maintain your machine by yourself at little but the cost of the parts required... but please DO NOT ATTEMPT ANY REPAIR YOURSELF if you think you may not have the technical know how to follow these technical drawings..hope this helps
SOURCE: GE Top Load Washing Machine -- Agitator will not cycle
Agitator's don't spin on wash cycle.
I would suggest washing the clothes without soap until they rinse clear. If you have hard water, the soap will not easily rinse out of clothes, or off of you when you use soap to wash or shower.
Reduce the amount of soap you use in each wash if this is the case. It sounds like your washing machine is working right.
SOURCE: screeching noise in maytag topload washer
The following link explains the problem you are having with your Maytag:
http://www.fixya.com/support/r387833-maytag_washer_squeaking_problem
It is common for the brakes on Maytag top loaders to wear and make noise, as well, as the snubber. There is a helpful tip that you can try to quieten the noise if it is the snubber. DO NOT oil it, or lubricate with any petroleum based products! This will ruin the unit and actually make the problem worse. NOTE: If the snubber is excessively worn, it was also cause vibration on the spin cycle.
If the brakes are worn, however, you can put a light film of oil on the brake pad. It is common for the pad to collect moisture in humid and damp climates and start to squeak against the brake stator. The brake pad consists of a rotor with a leather edge (pad). The leather can absorb moisture and begin to squeak against the brake stator. Oiling it slightly will get rid of the noise.
Confused? If you have questions, please let me know. I hope you find this information useful.
NOTE: There is a follow-up comment at the bottom of the link I provided from another user. The method this person used to release the tension on the brake can save you from having to purchase the brake release tool.
SOURCE: Agitator Not Working
My Hotpoint VBXR1090B top loading washing machine quit spinning during the rinse cycle and also quit agitating.
The water filled up and drained just fine --no leaks.
Here's how I fixed it in 5-minutes.
Tools:
Procedure:
