Format your flash in FAT32.
The LCD does not have the program to read the files so have the flash in a computer and change the file type. fore media you should select even one of the files and click on options then select restore to previous version the on the pop-up change the medai player where it says change with the icon on it. it will let you choose another media of your choice.
SOURCE: install games on samsung D900, says unsupported file format
Well it certainly is easy but people have made it difficult you don`t need to do much ok
I`ll provide you with easiest steps ever
1.download some games with both formats and put them in the same folder ok both extensions of the files would be like
EXAMPLE:- Driv3r.jad and Driv3r.jar
2.Also download Softick PPP 2.21*** just write it on google you`ll get it
3.Get A Bluetooth Device or Blutooth Dongle and connect it to PC, remember the blutooth icon below the left side of the task bar goes blue....
3.Now Activate Bluetooth on your Samsung SGH-D900 and go back to the main screen and enter the code #*5737425# and you`ll get a new menu open,the headline of that menu would be JAVA SERIAL
and Below that would be 1.PPP UP 2.Serial Download and 3.RUN TCK
4.Now after the softick is installed open it and an icon will appear on the screen on the taskbar below
right-click it and activate it be patient while it would be activating you`ll get a on-screen msg on your mobile that`ll be SERIAL CONNECT WITH DEVICE and you should accept it and then look back on the same menu of JAVA SERIAL then click PPP UP and it`ll take you to two more options just click BLUETOOTH and you`ll be headed back to JAVA SERIAL MENU.
5.Now You Need To Download The SAMSUNG JAVA UPLOADER similarly write it on google and you`ll find it easily now open it and A window will appear go for ADD
a window will open remember it only adds jad files don`t forget to get the jar file for the same prog.
and then add the jad file on the same JAVA MENU after all steps click serial download
GAMES WOULD BE INSTALLED AND ENJOY
Remember just after a game is installed repeat the same step but you would not go for PPP UP just go for serial download and its all done
SOURCE: how can install .jar file
Samsung phones could not rul .jar format...
but don't worry, you have to find .jad file of same application and use both of them.
also,there are some programs that make .jad file for a .jar file...
just look for them on net.
Ihope this helps...
SOURCE: i cann`t install java file on my mobile
Go to www.getjar.com and locate your mobile and download whatever games and other SW that you want, free. When you locate your phone, it will display SW totally compatible with your phone. Do not download any jar or jad files.
SOURCE: samsung S3310 Unsupported file type
Samsung GT S3310 is a type of JAVA phone that support application with extension .jar or .jad.
Because the phone resolution is 240x320 so u can download any application or game with resolution 240x320 into your phone and install it. Try to search it around the net. Here some link for u: http://www.mobileheart.com/cell-phone-games/1782-Samsung-S3310-Games.aspx
YBC (/\)
SOURCE: unable to install Java games on Samsung P520
when i type that code *#9998*4678255# ...screen show..*#9998*------* and nothing....what is that?...
Change the files into another format, secondly you can avoid placing the files in hidden folders..simply paste them in the flash within creating a folder.
