If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Circuit diagrams of SMPS section of many popular brand devices are given
Hello
The power regulator board in your Hitachi is not switching. It is an SMPS [Switched Mode Power Supply]. Normally for plasma TVs the power supply repair will be almost impossibele due to lack of component availability. If the fuse is OK, definitley the switching process has failed it it. There is an IC which oscillates at high frequency, whic its oscillation signals are given to MOSFET transistors to chop the incoming AC, converted DC voltage. These switched voltage is passed through SMPS transofrmers which it turn generates secondary voltages that goes to different circuit boards of your TV. The power board is the most important section in a Plasma TV. it must be perfect in every respect in terms of secondary voltages. If any one of this voltage goes over than specified, the main boar will get damaged. So it is adviced to replace it as card basis, rather than making "sugery" to it. The power supply board can be had from Authorised Hitachi Service centers. You just give the the exact model number of your Hitachi TV. They will give you the orginal power supply board. Never play experiments with Plasma TV. OK.
The most likely the TV has a power supply related problem. The most common thing to go out is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board. I can't say it's 100% the problem because I can't actually look at the tv over the internet. If by chance the TV is still under warranty, go that route. If not under warranty and If you have some electronic experience, you can purchase a Service Manual over the internet and diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, test points, and part# lists. Usually, cost under $20.
If the circuit breaker was tripped, more likely the fuse inside the TV power supply might also be blown. If that is the case there might be a short circuit in the power supply components, more likely on a diode or transistor/mosfet.
Contact these website to see if they have the parts for your plasma.
Good Luck.
Replaced two N-Channel Mosfet transistors(FQPF13N50CF-ND) and some faulty electrolytic caps in the power supply. I found the Mosfets online at Digi-Key. Mosfets are difficult to read. Only one read bad but I replaced both because they are in the same circuit. Set works great now.
