SOURCE: Planes Comparison
If you have a stack of hand planers and you do a lot of woodworking, you might want to buy a power planer. Power planer have a number of qualities that should convince you to keep the old hand planers but add that power to the group. Choose a power planer when you have a lot of planing to do. One thing about a power planer is that it is much faster compared to the hand planer. Use a power planer when you need to make rabbets or even scrolling. The power planer can do both of these jobs. There is a great deal of versatility about a power planer. Keep the cut smooth with a power planer. Frequently a hand planer needs to be lifted and started again. This leaves gouges and groves. A power planer has a continuous blade that leaves a smoother cut. Get more precision. The continuous motion of the hand held power planer and set depth cuts the specific amount that you want. Plane larger areas. You can plane doors quickly and easily with a few strokes of the power planer. Straighten a board easier with a power planer. You also can create chamfered surfaces with the power planer.
SOURCE: Need a user manual for mastercraft thickness planer
I'd suggest calling 1-800-689-9928 and speaking with one of the customer service representatives
SOURCE: I am looking for either replacement knives for a
Frezite of Portugal have agents in the States who will be able to assist you. Their products are very good, although not cheap, but are longlasting and hold their edge. I use them in my wood manufacturing business on all my machines.
SOURCE: I have a 12 5/16
go to home depot and purchase DELTA 12 1/2 inch blades. make sure they are centered so they don't rub the sides of the housing or grind off a little bit off each end.
SOURCE: craftsman thickness planer mod.no. 351-275210. looking
Are you sure that the model# 351-275210 is accurate? Sears Parts Direct is not listing this particular number. This may be because it is inaccurate, or the planer that you have is no longer supported. Searches on the internet have yielded little information as well.
If this model # is accurate, then you will need to contact your nearest store. They should be able to order you a manual, perhaps even print you one while you wait if the document is available. The store databases will sometimes have more information available than what is available from their website.
Please confirm the model #.
