SOURCE: Nikon D40
Hey climiocid,
If what you mean is your images don't display on the LCD screen after you take the picture your image review option has most likely been turned off. If your camera just never displays any images I would try doing a hard reset on the camera by shutting off the camera and opening the connecter cover and pressing the reset button which should reset the camera to factory specifications. When resetting the camera this way remember this resets the cameras' clock. If none of this works I would have the camera looked at by an authorized service technician. You can find an authorized service center by contacting the manufacturer, or you can always bring your camera to a Geek Squad® precinct in a Best Buy™ store and they can send it out for service. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
SOURCE: Nikon D60 highlight
When you have the flashing highlight areas, press the down arrow on the command dial and it will scroll through various playback screen options until you get to the screen you prefer to view.
SOURCE: Sd card won't click into place on my Nikon d60
Check your SD card, there may be a piece of it missing. Did the same to my camera and looking into the card holder, there was a piece of SD card lying at th bottom! (I used a needle to dislodge it!)
SOURCE: Nikon D60 use of Display to take pictures rather than view finder
The Nikon D60 does not have "live view" capability, so you'll need to use the viewfinder to frame you shots. If you need "live view" capability, consider purchasing the D80 or D90 instead with offer the feature...
SOURCE: Nikon D60 memory card problem. When i turn my
check your sd card, there's a tiny bar on the side that you can "slide" to unlock...
Hello . It may be due to sweating in the plastic that disrupts the camera monitor board. Remove the batteries. And keep the camera close to dry air and worms.
