Question about Dodge Computers & Internet
Serpintine belt on 2000 dodge caravan needs attaching
Any ideas?
    Habit-Forming:
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 3 Answers
I take it you mean installed. The belt sequence for the pulleys should be on the cross member under the hood over the radiator or somewhere in that vicinity. Follow that pattern and you will have to put a ratchet in the front og the belt tensioner to turn it down far enough to get the belt the rest of the way on. Go to youtube and do a search on how to do it. Someone will have a video showing how to do it.
Posted on Aug 17, 2019
SOURCE:
INSIGHTAEM
SOURCE: starter for dodge caravan 2000
DISCONNECT THE BATTERY, JACK UP AND SUPPORT YOUR CARAVAN. LYING ON YOUR BACK LOCATE THE STARTER WHICH IS ATTACHED TO THE ENGINE THROUGH THE BELL HOUSING .THERE ARE TWO 15 MILIMETER BOLTS THAT HOLDS THE STARTER ON . AFTER BREAKING THE BOLTS A 15MM WRENCH WOULD BE USEFUL.
Posted on May 30, 2008
leetamara
  • 702 Answers
SOURCE: 2000 Dodge Caravan Serpentine Belt issue
I do have one but I have to send it to an email address, I don't know how to put diagrams on here. shoot me an email to send the diagram to. thanks Lee
Posted on Jun 13, 2008
SOURCE: 2000 dodge caravan Diagram For Serpentine Belt
get a diagram
Posted on Jul 07, 2008
  • 3 Answers
SOURCE: How to replace serpentine belt for 2000 Dodge Grand Caravan?
Mine fell off twice so far once when going through snow and other was going through rainstorm had to use jack wrench to pry down and slip on belt which was hard to do and don't advise you to try. Ok the pulley directly under the alternator and in the middle of 3 other pulleys is the one that is the tensioner. To do this right use a 15 millimeter or 5/8 socket or open end wrench, the longer the handle the better so you can get good leverage maybe you have a pipe to slide over handle. There is a diagram of the way the belt goes on under the hood. I have a 2000 Dodge Grand Caravan
Posted on Nov 29, 2008
MNfisherman
  • 11896 Answers
SOURCE: need diagram for replacing serpentine belt on 2000 dodge caravan
I need to know which motor you have.
After you let me know, I will go to this website to find your answer:
http://www.autozone.com/N,316192/shopping/vehicleSelect4.htm
Posted on Jan 17, 2009
I need the routing system for the serpintine belt for a 94 dodge grand caravan es 3.3 liter v6
Google it
There are pictures or diagrams on the internet
Next time make a diagram-- before you remove any belt
Should be a diagram under the hood on most vehicles
Jul 14, 2014 | Dodge Ram 2500 Cars & Trucks
Need a serpintine belt diagram for 2000 dodge durango 8cyl 5.9 l
all diagrams can be found by googling the manuafacturer for that particular serpintine diagram...I did it for my 2000 monte carlo
Dec 15, 2011 | Cadillac Cars & Trucks
The serpintine belt keeps slipping off the 3.3 engine
You either have a bad (wobbly or loose) pulley or tensioner is worn out, or belt is worn out....Mike
Jun 22, 2011 | 2000 Dodge Grand Caravan
I am wanting serpintine belt diagram for a 1993 dodge caravan 3.3 6cyl
Accessory drive belt adjustment-3.3L and 3.8L engines
Click to Enlarge
All of the belt driven accessories on the 3.3L and 3.8L engines are driven by a single serpentine belt. The belt tension is maintained by am automatic tensioner.
  1. Raise the front of the vehicle and safely support it with jackstands.
  2. Remove the right front splash shield.
  3. Release tension by rotating the tensioner clockwise.
  4. Remove the belt and install a replacement.
  5. Proper belt tension is maintain by the dynamic tension.
  6. Install the right front splash shield. Lower the front of the vehicle.
Oct 23, 2010 | 1993 Dodge Caravan
Serpintine belt replacement
OK, click on the link below to be directed to a full size photo of your belt routing diagram.
2000 Grand caravan Serpentine Belt Routing
Please rate and have a great day:)
May 18, 2009 | 2000 Dodge Grand Caravan
1995 plymouth voyager.i need serpentine belt diagram.its no longer under hood
Find a pic of routing here:
http://www.2carpros.com/forum/1992-dodge-caravan--serpintine-belt-routing-map-vt170348.html
Good Luck
Dean.
May 03, 2009 | 1995 Plymouth Grand Voyager
199 dodge caravan 3.3 tensioner
yes you must jack the vehicle up put it on jack stands for safety, and around the power steeirng pump under neath you will see the nut that is holding it you will need a long extension and a swivel.
should be 15, 14, or 13 mm
when installing the belt itself, you must put it on the idler pulley last that is the other smooth pulley, otherwise it will be a bear to get on. good luck.
Mar 09, 2009 | 2000 Dodge Caravan
Serpintine belt
nope just the idler pully or the belt tentioner
Jul 07, 2008 | 2000 Dodge Caravan
Computers & Internet Logo
111 people viewed this question
Top Dodge Computers & Internet Experts
D. E. Hev
gbob59
Marvin
Marvin
Are you a Dodge Computer and Internet Expert? Answer questions, earn points and help others
