THE BOTTOM BRACKET CRANK GOR MOUNTAIN BIKE THIS IS IN INCHES THE LENGHT 4 INCHES AND 5/8 THE ROUND INCERT IS ONE INCH AND 3/8 I NEED THE SIZE IN MILLMETERS
4 5/8" is about 117mm, I'm assuming that spindle length from end to end with the cranks and bolts removed.
1 3/8" is about 35mm, and that's not a measurement used in selecting bottom brackets.
Typically, Bottom brackets sizes are Shell Size 68/73mm x Spindle length, in your case 117m, or anything close to it like 118m. I upgraded a BB on Vintage bike, the spindle length was 125.4mm, I used a 126mm BB replacement. Like 122.5mm are sold as 123mm.
Multiply the size in inches by 25.4 converts it to metric.
SOURCE: A code for 27inch 700 wheels for sigma bicycle computer needed
Dear spinnerrr
this is the four digit number you are looking, it should be between 2145 and 2149
Regards
SOURCE: Blue Dots at bottom of screen
i have 6 grey perfect circles on screen of sony 52 inch kdlw3000
SOURCE: DIshwasher doesn't drain. 3-4 inches of water sits in the bottom.
A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again.
Many dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly. With these systems, the motor always rotates in one direction. When it's energized, the drain valve diverts the water.
Other dishwashers simply reverse the direction of the motor to drain the dishwasher. These units don't have a drain valve. Instead, there's a drain hose connected directly to the pump housing.
SOURCE: screw size to bolt panasonic 32 inch lcd into
Metric M5 or M6, they should come with the mounting kit.
