Plumbing Logo
David Magee Posted on Jul 26, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Spray-ette tree and scrub sprayer, when I connect it to hose and turn on ,water does go through sprayer about 25 ft put also leaks ptetty good though 2 vent holes near the hose connection, any ideas
Tony Crow
Level 3:
Master:
  • Master 578 Answers
  • Posted on Oct 03, 2019
Tony Crow
Master
Level 3:
Master:
Answers
578
Questions
Helped
143258
Points
1638
Replace hose connection
  • Brett Pate
    Brett Pate Apr 01, 2023
    This is really poor answer. the hose connection is fine, the water is coming out of the vent holes in the handle. also so vague and impossible to replace the hose connection on these sprayers.
2 Related Answers
Anonymous
  • 116 Answers
  • Posted on Apr 21, 2009
SOURCE: Srayer leaking down the hose from pivot joint near spray head
there is an oring in that connection that is most likey bad. turn water off and disconnect coupling to spayer. remove the black oring and match it up at your local hardware store. when installin it lubricate it with vaseline for ease of insatlltion and to help protect it during installation.
Anonymous
  • Posted on Sep 01, 2009
SOURCE: I have a ortho tree & shrub spray-ette hose
sound like the inside suction hose is loose or not fitting correctly. i had a similar problem and wrapped some duct tape around the tube then snugly fit it inside the cap. no outside air suction and it works fine. i've had mine going on 15 years and use it constantly.
1helpful
My ortho spray nozzle doesn't spray product out. I have replaced batteries but doesn't make a difference.
I tried a few things and I'm not sure which was the trick or if it was a bit of all. I detached the sprayer hose from the container and put the hose and sprayer end in a bucket of water in case old spray was in the nozzle then tried spraying it in and out of the bucket for a while trying to dissolve any plugs. Still didn't work. Then I put the container up higher than the hose and sprayer and tilted container and tried spraying for about 15- 25 seconds and it started spraying again. Good luck!
2answers
Leaking faucet
I've had problems with the O-rings at the head leaking, feeding back inside the corrugated hose covering, and pooling under the sink. Might be your problem as well. Verify by holding the head downward, and look for water beading out further up the hose.
2answers
Only one winshied wiper spray works
Check the rubber hoses to the sprayers. If they are on the hood they can come unplugged when you open it. Have a friend work the sprayers as you watch for leaks. An old toothbrush can be used to clean spray nozzles by scrubbing over the hole.
2helpful
Looking to replace triger (leaks)
NorthStar brand equipment comes from Northern Tool. You can't replace the trigger, but they sell the replacement spray wand here and it's only $11.99. There are other wands, some longer, etc. They are pretty universal -- you just slide them onto the hose and tighten the band clamp. Good luck! If this is helpful, please rate my answer, thanks!
3helpful
Sprayer leaking from inside handle mechanism
although it is possible that the spray head has gone bad, it is more likely that the diverter mechanism inside the kitchen faucet needs replaced. When this part is defective, it allows full pressure from the faucet to go to sprayer head even though the sprayer is not triggered. The sprayer is not designed to handle full pressure when it is not spraying.
1helpful
I have a ortho tree & shrub spray-ette hose end sprayer. The instructions say to add product and fill to gallon mark, then attach to hose and turn on water and spray. It isn't plugged the water comes...
1helpful
Mold and smell from Maytag washer
The mold will be growing in the upper parts of the agitator basket above the water line. Spray these areas with a bleach/water mixture using a spray bottle. Turn off the hot water valve to your washer. Disconnect the hose connected to this valve. Connect a leak free garden hose to the valve. Connect a garden sprayer to the other end of the garden hose. Turn the hot water valve back on. Check for leaks. Use the garden sprayer to rinse and remove the mold. Be careful to keep all of the water in the agitator basket. Turn off the hot water valve. Reconnect the hose from the washer to this valve. Turn the hot water valve back on. Check for leaks. Run a wash cycle with an empty load.
Top Plumbing Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Plumbing Expert? Answer questions, earn points and help others
