Refrigerators Logo
Cathy Cross Posted on Jul 25, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
IS THEre RESET BUTTON ON THE MAYTAG MODEL LGHB2869LF4. I just filled my refrige today and went to get crushed ice stopped working and all the lights went out.the fan is trying to work but not well.
john h
Level 3:
Top Expert:
  • Maytag Master 29,494 Answers
  • Posted on Apr 16, 2020
john h
Maytag Master
Level 3:
Top Expert:
Answers
29494
Questions
0
Helped
7560599
Points
193449
Unfortunately this is not an issue that can just be reset. No real troubleshooting is needed based on your symptoms . unfortunately this is a well known problem for this particular refrigerator and you won't see any signs of failure but the problem is the high voltage control board on the back of the refrigerator behind the 8? x 8? access panel. if you pull the refrigerator out, there is a panel on the back and if you remove it that board behind that panel test it but most likely needs to be replaced.
5 Related Answers
aborcass
Ron Coons
  • 2651 Answers
  • Posted on Mar 22, 2008
SOURCE: Always dispenses CRUSHED ice
try removing the ice bucket, and on the back wall is a hole approx 1.5 inches square that the brass bar attached to the rear of ice container inserts into,(you may have to put hte container back in partilaly to look under and watch where it slides into) inside thatcut-out is a plunger that slides up and down activating the crushed/cubed option.you can sick you finger in the hole you should seee a plastic hoop that would catch the brasss bar.Try pushing and pulling hte hoop up and down if it does not move freely, youll need to replace the solenoid assy. if it does, then pull allthe way to the lowest positon and make sure when replacing the ice container that the bar falls with in the hoop itself
BNewberry
Bill Newberry
  • 93 Answers
  • Posted on May 16, 2008
SOURCE: ice crusher has stopped crushing
There is a little bar that is on the ice bucket. That bar has to go into the middle of the plastic square that is on the back wall of the freezer. Try Pulling out the ice bucket, get a hair dryer and run the hair dryer on the back wall of the freezer right above the hole where that little bar goes. After you run the hair dryer for about 10 minutes or so put your finger in the hole and pull down on the plastic square. Make sure when you put the ice bucket back in the freezer, the bar goes inside the square hole, not under it, not over it. In it. If that doesn't fix the problem you probably just need a new solenoid. Part number 5304404333
Let me know how you make out. Good Luck
Bill
Anonymous
  • Posted on Dec 07, 2008
SOURCE: Maytag refrig (french door) water and ice on door stopped.
1) Electric Water valve check up.
2) Water/Ice dispenser control check up
3) frozen plastic pipe inside door or/and chilled water container frozen
4) old water filter (clogged)
Anonymous
  • 3361 Answers
  • Posted on Mar 09, 2009
Replace the switch behind the front panel on the freezer.
Anonymous
  • 1543 Answers
  • Posted on May 23, 2009
SOURCE: ice maker only crushes/does not cube
Remove the ice bin. Look at the back wall, behind where the bin was. You should see a rectangular hole, about 1.5 x 1 inches near the bottom of where the ice bin was. There should be a white plastic part inside the hole. This plastic part should be able to be lifted up with your finger, and drop down again when you release it. If is does not move, it may be frozen, or the electrical solenoid connected to it may have melted. If the part moves freely, just replace the ice bucket and try to dispense cubes again. (the metal arm sticking out the back of the ice bucket might have gotten on the wrong side of the white plastic part in back)
GE frig not cooling, both refrig and freezer. started with ice/water dispenser not working.
WR55X10942 Main Control Board This sounds like motherboard failure. I am not sure what your model number is but that will be important should you have someone to help repair your refrigerator. These problems are common on the Artica Profile Models. I will be here to help you repair if you should choose, Thanks Sea Breeze
2answers
LG refrig with freezer on bottom, french doors Model #LFC237605SW lights went out - is there a reset button?
There is no reset button. Make sure the light bulb has not burned out. It's possible that ice has frozen the light switch. Use a hair dryer to the ice switch to see if it will melt the ice and release the switch. Good luck
7helpful
3answers
My maytag MSD2556ae side by side refrigerator water/ice dispenser may be locked. Is there a method or code to unlock. The water dispenser started shooting water out with no warning and the dispenser light...
I have a Maytag model 2556 AE refridgerator. The ice maker works but the ice and water dispenser, the light and everything else on the front of the unit doesn't work. Is there a fuse that operates this or is there other problems? Thank you Bob
1helpful
Change water filter for a maytag plus refrigerator
press the light switch button inside of the refrigerator five times.
Ice crusher has stopped crushing
3answers
Ge side by side water will not come out of door dispense
The water switch went bad or the water valve. Switch the two wires on the water valve on the back of the ref. Press water switch on door if water fills ice maker valve is bad,if not,door switch is bad.
2answers
Maytag refrig (french door) water and ice on door stopped working at the same time.
Ice dispenser not dispensing.
the hex wrench your after is know as nut ddriver screw drivers / you can remove the auger assembly quite easily the activation switch is located in the door assemby. be carefull the auger is powerfull.
2answers
May tag m2260i side by side
that is not a good model number the model number is in the refrig section post serial also they are together.
1helpful
Top Maytag Refrigerators Experts
vince
Johnny 1000
Jesse Walters
Jesse Walters
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
