Only one temperature control??
Good day,
Yes, they are made. The temperature in the fresh compartment will be no issue, since you have control in that compartment.
The engineers designed the balance between the two compartments so the freezer would be normal if the following conditions applied.
1. The room temperature is between 70 and 90 degrees.
2. The machine has normal usage. I.E. 8 to 20 door openings of the fresh food door.
The freezer would start getting warmer if the room temperature dropped much below 70 degrees. or..
If the machine had extremely light usage with very few
door openings, or a combination of both situations described above.
With dual controls, and both set at normal, the above conditions would occur anyway, except you could over ride the normal settings to compensate.
Many people have this setup, and experience little trouble, but without knowing your life style replacing it would be your choice based on the facts given.
Thanks for using FixYa
