SOURCE: ti 84 plus silver edition language change
ON, Apps, scroll down until you see English, press enter. There might br several language choices there...Dutch, French, etc...
Even try: 2nd, mem, 7, 1, 2, enter to reset all RAM.
SOURCE: How to change the faceplate on the ti-84 silver edition
Look at the bottom of ur calculator. not the back the bottem. and u should see where the gray area meets the white area. There should be a small lip at the bottom of the calculator. Pull back the lip, it should come off with minimal force. That is how u remove the faceplate
SOURCE: Change TI 84 OS to TI 89 OS??
And why, pray tell, would you do such a thing? You will ruin your Ti84 Plus Silver Edition and will not have a working TI89. Besides, TI connect will refuse to transfer it.
If you like the capabilities of the TI89 Titanium, buy a cheap or used one on e-bay or amazon.com and spare your TI84PLus SE.
SOURCE: I have a TI 84 plus silver edition. Won't turn
The problem may be due a screen that is too light to see anything on it. Adjust the screen darkness.
You can also connect it to the computer to see if TI Connect finds it. If it does, update the OS to version 2.53MP.
You change the backup battery if the calculator tells you RAM CLEARED each time you turn it ON.
SOURCE: my ti-84 froze up while I was working on it. I
Having gone over a month without a response, I assume it was just a screen problem.
