Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker Logo
Posted on Sep 05, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Water is accumulating in the refrigerator
Water is accumulating and freezing in the refrigerator
Anonymous
Level 3:
  • Whirlpool Master 1,606 Answers
  • Posted on Sep 05, 2009
Anonymous
Whirlpool Master
Level 3:
Answers
1606
Questions
Helped
569783
Points
5623
Remove the food from the freezer and icemaker (3 screws and a plug hold it in place ) . Remove the screws holding the back panel of the freezer in place , and remove the panel . Using a hair dryer , below the coils , start in the middle , and defrost until you see the drain hole . Keep defrosting the hole , until water starts to drain thru . Use a small piece of hose inserted into the drain , and blow thru it , to clear out any debris accumulated in the drain line . Hot water helps to clear the ice from inside the hole also . To make this a permanent " fix " , get a piece of aluminum solid wire ( 14-16 guage , like an appliance ground wire ) about 8 " long . After the drain is clear , where water runs thru , insert 1 end into the hole as far as it will go without any force , bending slightly if necessary . Wrap the other end around the black tube ( defrost heater )above the hole about 1 - 1 1/2 turns . Whenever the fridge goes into defrost , the heat will transfer to the wire , therfore , keeping ice from blocking the drain again .
I have water on floor under refrigerator.There is no water supply line to this frig.
If the refrigerator is leaking water it's possible that the refrigerator has a clogged or freezing defrost drain. If the defrost drain freezes the defrost water will overflow the drain and drip down to the bottom of the compartment, If enough water accumulates in the bottom it can run out onto the floor.17 May 2013
SOLVED: Water leak in refrigerator? - Refrigerator - iFixit..or go to this link might help you as well....
water on floor under refrigerator Google Search
Water condensating in refrigerator side
Check for any air leaks within the unit's door and seal area. See if you notice any blockages in the damper door or switch that is between the two doors. Then contact a professional.
Water accumulating and freezing on bottom of freezer compartment
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Freezer drain not working. water accumulates and freezes in bottom of freezer compartment and sometimes will melt/leak onto floor
use hot water and turkey baster . force the water down the drain till it clear's to prevent it from freezing again install drain heater . some model's need them.
We have a side by side Maytag refrigerator. Model # MSD2758DRQ Serial # 14043813YU. The bottom of the freezer is accumulation water and freezing. We turned the ice maker off, and it continued to accumulate...
your drain in the freezer is plugged or frozen ...remove the back panel and pour HOT water down the drain until it runs thru.... hope it helps
Kenmore refrigerator 106.72206201 - accumulating ice and water
Probably a clogged drain line in the freezer. Unplug it for 2 days and leave it open. Reset controls to 3 and C or factory settings clean the coils on the bottom outside with a vacuum and a brush and restart the fridge.
Water accumulates at the bottom of the freezer unit and leaks
You must clear the drain of anything that would cause water to pool up after each defrost cycle. Check your door gaskets for wear. Air entering the ice box can cause excessive frost.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
1helpful
Water from freezer dripping into fridge freezing and accumulating in the crisper drawers.
Maytag , MZD2752GRW; Water accumulating and is freezing in bottom of the freezer, then runs out the door on to floor.
1helpful
Refrigerator is freezing up inside at the top.
check the seal on the door it might be that because when the water vapor in the air gets in it will freeze on the top.
1helpful
Water accumulates and freezes in bottom shel
The drain for the defrost is blocked, probably with ice. If drain is frozen it will need to be defrosted, and a heat probe attached to the heat element and down through the drain hole. If not frozen there could be blockage in the drain cup depending on the model.
Top Whirlpool Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
