Heating & Cooling Logo
Barry Hanniman Posted on Jul 16, 2019
Honeywell focus pro 6000,how to. Hangs from F to Celcius
Isabella Tello
Level 1:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 3 Answers
  • Posted on Jan 23, 2020
Isabella Tello
Contributor
Level 1:
Welcome Back:
Answers
Questions
0
Helped
1113
Points
To change to F to C follow the next steps:
1. Press and hold and the same time (simultaneously) the up arrow and fan button (middle button under the screen) until the display changes.
2. Press next until you see 14 on the left and 0 on the right.
3. When you see the 14 on the left and the 0 on the right, press up arrow to change number 0 for a 1.
4. Then press Done and you will see your normal display in Celcius.
5 Related Answers
Anonymous
  • 540 Answers
  • Posted on Sep 04, 2008
SOURCE: i have a honeywell focus
W== heat which we'll call this w-1! w2== second stage!
Anonymous
  • 182 Answers
  • Posted on Sep 24, 2008
SOURCE: We have a Honeywell A/C
the honeywell is just a thermostat.my guess is the capacitor went out in the condenser when you lost power.turn the temp down on the thermostat and hit the hold button.....if it does not cool,call a service tech.good luck!
Anonymous
  • 13 Answers
  • Posted on Oct 26, 2009
SOURCE: I purchased a 2005 home that was vandalized. It
They will work, most zone controls only require the use of 1H/1C thermostats, the system stages and functions are controlled by the board itself.
http://customer.honeywell.com/TechLit/pdf/PackedLit/68-0237.pdf
knightheatin
  • 149 Answers
  • Posted on Jan 14, 2010
SOURCE: how do i change my focus pro 6000 th622od1028
go back to installers set up set display to f
Anonymous
  • 36 Answers
  • Posted on Jan 24, 2010
SOURCE: have a honeywell focus pro 6000 TH6220D1036 and it
get an external thermastat installed and check the internal limit thermostat.
I have a honeywell focus pro 6000 temp in house doesnt change unit runs constatly. thermostat says 78 thermomiter on other end of house says 72. changed batteries
It's possible you have a lot of dust build up inside the stat. If it has batteries remove face from wall and blow out. Take outside to see if temp will change. Plug the hole in the wall where the wire comes through. If all fails, replace. Turn power off, take wiring picture, replace, turn power on. Good Luck!!
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Honeywell focus pro 6000 thermostat
Right below the w setting on the base plate is the o/b connection. Put the O wire in this slot. During the initial test for heat and cool, the bias for cool for function 2 is 0 and for heat it is 1. To reach the programming press fan and Up arrow. Press next to reach function 2. Be aware the the O wire is energized and operates the reversing valve. Some manufacturers energizes the reversing valve to go into cooling, and some leave it deenergized to be in cooling. Select either 0 or 1 to make the system perform in the correct mode.
Hope this helps.
1helpful
2answers
Lost directions to program a thermostat
i have a pro 6000 t stat it shorts cycles any clues to change the off set
We have a Honeywell A/C (we believe it's a focus pro 6000) that is not working properly. The A/C unit itself is running but the vents inside the house are not cooling. We think it's a problem with the...
Top Honeywell Heating & Cooling Experts
Paul Carew
john h
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
