Nokia N70 Cellular Phone Logo
Posted on Aug 29, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My bluetooth is very slow
Bluetooth is not working properly,take long period to recieve data.if some data is recieved in inbox,inbox cannot be opened.some times saved mp3 plays shows format does not supported
satyajit Naskar
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Mar 26, 2019
satyajit Naskar
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
281
Points
Write your answer...my mobile update
Anonymous
Level 3:
President:
  • Nokia Master 511 Answers
  • Posted on Aug 30, 2009
Anonymous
Nokia Master
Level 3:
President:
Answers
511
Questions
0
Helped
153358
Points
1430
Try to upgrade ur software version in nokia gallery ur work is done ur mobile will work smoothly nd bluetooth too...rply
Anonymous
Level 2:
  • Expert 51 Answers
  • Posted on Aug 29, 2009
Anonymous
Expert
Level 2:
Answers
51
Questions
Helped
7678
Points
133
Try resetting your phone to factory settings
1helpful
Hi, i have a storm 9500. my problem is that i cant recieve any data via bluetooth. it was working properly but since i upgraded my software , it aint working anymore.. i can stil send but cant receive via...
When you open Manage connections in the MENU thers is a option SET UP BLUETOOTH then search for the open devices which are visible then pair it by using the sme pass key then when your done with pairing you go to MEDIA then when you open media and then press BB button which is the 2nd button from botton of the screen their you will see an option Recieve using Bluetooth and the screen displays waiting for connection and then you will be able to recieve any file video or piture .
2helpful
I have a kenwood excelong kdc-x993. my bluetooth compatible phone is paired with my reciever, and has been working fine for two months.Suddenly it stopped working, and the bluetooth doesn't work at all. On...
Try deleting the stereo from your bluetooth profile in your phone. Then try disconnecting the positive battery lead for a minute or so and reconnecting to reset the stereo. Then try again. If not, contact Kenwood support, and if it's still under warranty period, I would complain :)
1helpful
I am not able to recieve any data through bletooth
try resetting the settings of blutooth delete the history like names of devices connected... switch off ur cell remove battery and sim . try again. if problem persist ..ur phone must be still under warranty period so go to the samsung outlet..
When I bluetooth music to the nokia N97 phone it ends up in the text message inbox and cannot be played HELP
all of the files that you send in a phone via bluetooth is normal to recieved into inbox messages. once you recieve the file open it in the inbox, then goto options and save it to memory card.after that you can now delete it on your inbox.Goto music player and and goto option then click update music library, you can now play all of the music that you sent.hope this helps..enjoy
Whats the infered for
its for sending and recieving files . for example if the other phone , device or laptop also have infrared than u can recieve and send file to that device . its work same as bluetooth but the real difference is between ther distance infrared only send and recieve data on range of 1 metre but bluetooth can send and recieve data upto 100 meter .thanks and take care of urself bye.
May 09, 2009 • Cell Phones
How to move the reieved data to it's folder?
you select the receive data click /option/ move to / open memory card/ select folder as your wish.
6helpful
2answers
My blackberry bold does not recieve data via bluetooth
I think you read wrong praky, capt said already paired. The correct solution would be as follows:
1. Open the Media app.
2. Select a media type (e.g. Music)
3. Press Menu.
4. Select Receive Using Bluetooth.
5. Select Yes. (It will then ask you the location you want to save to but of course by default it will select the proper folder)
6. Select Save. (Transfer will begin
Bluetooth
it depends on the cell phone to u sending or recieving...see if u r sending to an nokia phone..the nokia phone is slow in recieving...but ur phone cant force it take data fastly...so it happens...as i've seen v3i to v3i its fast...even stil its an prob restart once n use...
ne other prob's do tell me..N plz do rate me
cya
2answers
Bluetooth wont recieve files but allows you to send them
Check out the space avail. in the handset or memory otherwise clarify the error
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
